What's the difference in running "pure" veg oil and "sunflower" oil
Just wondering if it's ok to run a 306 with bosch pump on sunflower oil? As I've just got a load cheap. And wondering what the main difference would be in running just normal veg oil and sunflower oil (I'm new to running it!)
Any advice appreciated
Sunflower oil is fine mate. It is actually better imo it smells better and is thinner so it's better on startup
(12-07-2014, 10:09 PM)aggyj17 Wrote: Sunflower oil is fine mate. It is actually better imo it smells better and is thinner so it's better on startup
Cheers Smile just got 50L from tesco for £40
Gonna get some more while it's on offer Big Grin
The 2 5l for £8 deal. That's where I've been going aswell :-)
(12-07-2014, 10:14 PM)aggyj17 Wrote: The 2 5l for £8 deal. That's where I've been going aswell :-)
Yeah, only noticed other day so thought I would give it a go haha
that's the stuff . . .Smile
Its really hard to start on Sunflower oil
(17-07-2014, 09:09 AM)kelvsere Wrote: Its really hard to start on Sunflower oil
easier than veg or soya . . . . .and it shouldn't be hard to start at all, sounds like you need new glow plugs fella. . . . Smile
guess you're just getting your post count up, i'll leave you to it then lol
Haha yes trying to , i used to have a corsa D , it wouldnt start on sunflower oil at at all , it was a bag of %^&**& though, started easy on pure veg , so must be a diff
(17-07-2014, 09:14 AM)kelvsere Wrote: Haha yes trying to , i used to have a corsa D , it wouldnt start on sunflower oil at at all , it was a bag of %^&**& though, started easy on pure veg , so must be a diff
yes there is, sunflower is quite a bit better than veg . .so don't understand that problem at all.
Corsa D's are CR engines aren't they? That'd probably explain it lol..
Yeah i wasnt expecting it not to like it but it only just started on the stuff , i tried it a second time by using half veg and half sun , and it took a fair few turnovers to kick up .
long as it doesnt have palm oil in the mix you should be fine.. palm oil has a higher gel temperature which means you will run into problems with it if it gets cold!
/Toseland
Is there a specific pump you need for this - I was led to believe there are two possible types - Bosch and Lucas.
But the seals on the Lucas wont last.
My has been at this for a while on Audi's - he has a preheater tank for Winter time and also he recommended adding some diesel to the mix to keep the tank circulating....
I've done this before with a Citron BX estate with 100% ra*e seed iol and it was grand - we called it the batter burger cos of the smell from behind......
ra*e seed oil is top stuff but noramlly most expensive...
a quick search will find 100s of threads asking what pump to use for veg...answer is always the same - BOSCH!
