Reprogram a key fob (106, 206, 306, 307, 405 ,406 ,605, 806)
Guide: Reprogram a key fob (106, 206, 306, 307, 405 ,406 ,605, 806)
FOUND THIS ON THE NET ANY THOUGHT IT MIGHT HELP A FEW PEOPLE OUT
106 PLIP PROGRAMMING
Procedure
1. Unlock the vehicle using the working key.
2. Press the LOCK button 2 times within 20 seconds.
206 PLIP PROGRAMMING
CENTRAL DOOR LOCK (1 BUTTON PLIP KEY)
Procedure
1. Ensure all doors are unlocked using the key.
2. Press and hold plip key button until LED stops flashing.
3. After releasing button, LED will light constantly.
4. Press the Plip Button once, and LED will extinguish.
5. Open the door and hold the Plip key near the Ignition switch, and press the plip button one time.
6. Turn the ignition ON, and wait 10 seconds then turn ignition OFF.
7. After 5 seconds, Plip should now operate.
CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP KEY)
Procedure
2. Press and HOLD the large plip key button while the LED flashes continuously for 20 seconds. After 20 seconds press the small deadlock button once while still holding the large button.
3. The LED will stop flashing.
4. Release the large button and the LED will light constantly.
5. Press the large button one time, and the LED will go out.
6. Open the door and hold the Plip key near the Ignition switch, and press the large plip button one time.
7. Turn the ignition ON, and wait 10 seconds then turn ignition OFF.
8. After 5 seconds, Plip should now operate.
306 & 806 (1998-) PLIP PROGRAMMING
Procedure
1. Turn the Ignition switch to accessory position using the key, without the remote plip attached.
2. Hold the Plip key close to the central locking receiver mounted in the roof console.
3. Press the large plip button, then the small plip button on the remote.
4. Repeat for second Plip key if required.
5. Turn ignition OFF.
6. After 5 seconds, Plip should now operate.
406, 405 & 605 PLIP PROGRAMMING
The 406 deadlocking remote control has specific button controls, and if the vehicles has two controls, one is set as primary and the other as secondary.
When replacing the Plip, a Primary or Secondary Plip are different part numbers and must be ordered as required. The white label inside the Plip is labelled PRIM and SEC.
Procedure
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds, press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
6. Test Plip’s for correct operation.
NOTE : On some 406 models, Plips cannot be re-synchronised unless the battery has been disconnected for 1 minute.
806 (-1998) PLIP PROGRAMMING
Procedure
2. Hold the Plip key towards the receiver at the front of the vehicle.
307 PLIP PROGRAMMING
Procedure
1. Turn the Ignition switch to ON position using the first key.
2. Press the LOCK button for 10 seconds.
3. Remove key and wait for 10 seconds.
4. Check Plip key operation.
5. Repeat for second Plip key if required.
6. Turn ignition OFF
206 PLIP PROGRAMMING SYNCHRONISATION—BSI
Procedure
1. Insert Ignition Key.
2. Press the small Black button.
3. Switch the Ignition ON
4. Keep the lock button pressed for 10 seconds.
5. Release lock button , switch ignition OFF and remove key.
6. Close all doors and press the lock button 2 times.
NOTE : If Plips still do not work, start the vehicle and then turn OFF. Open and close the door, and check Plip again. This is also necessary after a new BSI system is fitted.
******** IMPORTANT: PLEASE REPEAT STEPS IF NOT WORKING ********
You need to tune your key fob into your cars alarm system. Simply turn you ignition to the 1 position, or it maybe 2, & hold the key fob about 10cm away from your sensor for about 10-20seconds (with the button pressed of course).
If you have only 1 key then unscrew your key from the fob and just use the blade to turn the ignition.
Other Peugeot Tips:
BOOT PROBLEM!!!
For some unknown reason the key never fits the lock???
The reason the lock does not work is NOT down to the motor or loose connections.
If you open the boot, at the top of the door on the right hand side you will see a rubber sleeve which goes back into the car.
If you cut this open you will see 3 white wires (and a blue one as well i think) one of these wires will be broken, all you have to do is find the other end (usually still in the sleeve) and reconnect.
The boot lock will then work fine. It seems to be due to repetitive opening and closing of the boot.
Renovating/Repairing your Key Fob Housing;
http://www.peugeotdiesel.com/306_Fob_Repair.html
Other methods:
Your locking plip should have 2 buttons on it:
1, Unlock the door with the key
2, Press and hold the large plip button (the light on the key should be flashing) wait for 20 seconds and press the small button on the plip once, the light should stop flashing
3, Release the large button, the light on the plip should stay on
4, press the large button once, the light goes out.
5, Enter the car, hold the key next to the ignition barrell, press the large button once
6, Switch the ignition on, wait for 10 seconds and switch off.
7, wait for 5 seconds, the plip should now operate.
If it doesn't you either have a faulty key or control unit (BSI) - go to a Peugeot dealer.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Just resynced my key on my w reg phase 3.
I read this from my manual.
On the key buttons the big one is A, little is B.
1. Switch on ignition
2. Switch off ignition
3. Switch on ignition
4. Instantly press A button on key fob
5. Turn off ignition and try your new rcl Smile
I guess this only works for the remote locking transmitter, what about the steering wheel lock? (extra chip in the remote, see pic)
My car didn't come with a code and only have one key.
[Image: steeringwheelimmobiliser_zpse41599b1.jpg~original]
That needs to be programmed via Peugeot planet and you need your security code which you can get from pug for £20
How about the keys that come with the Rallye? it only has one button on it? how would you re-program this, i have been trying to do mine for ages now lol
