ecu kit
Hi. If I fitted the whole kit ,ecu ignition key bsi ,transponder from the same car would it have to be programed in for it to start or will it start OK thanks.hope this makes sense p/s all the numbers are the same as my car .
I think thats everything. I have no idea but im sure someone will be along shortly. I believe youd need the door locks too?
Oh yer got them to thanks.
The coded parts are ECU, BSI and the key fobs.
You can keep your existing key barrel and door locks, just put your key blade into the replacement fob. Smile
Cheeers for that they, but will it need any progaming in or will it start up no probs ta .
You've swapped everything and everything matches so nothing should need reprogramming as far as I'm aware.
As Rowell says, as long as you change all the coded parts together they will not need recoding.
Many thanks can't wait and try it tomorrow good news ,great site .btw
