10-05-2014, 11:17 PM
		More hammer/arch roller will fix it mate, wouldnt raise her as shes beautiful. Also when you fit the 21mm bars you might find she sits a little higher anyway.
					The Racetractor. The End.
		12-05-2014, 12:50 PM
		Yeah....still need clearance though...guna do more bashing...if still no good, will drop to 17mm spacers on rear
		12-05-2014, 01:56 PM
		Relay? Would the relay affect heat, fan and AC/Ricurc control? Wishes for more power...
		12-05-2014, 08:30 PM
	 (12-05-2014, 01:56 PM)Piggy Wrote: Relay? Becauseitsfrench   ![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg) the smokey old bus that sounds like a tractor...
		12-05-2014, 08:36 PM
		Rip them all out and check for poor connections or burnt plugs
		12-05-2014, 08:40 PM
		Yeah cool...just found similar info/issues/solutions on 306gti.com
		12-05-2014, 09:09 PM
		My indicator burnt plug created other issues in my dashboard, just French electrics lol
		14-05-2014, 07:07 PM
		Found the issue...wire dodgy on the plug. Found this after paying for a replacement set. Oh well. At least I found the issue...and now have a spare fan and heater controls!!
		16-05-2014, 08:52 PM
		Having some rubbing issues with the rears due to the extra 10mm poke...did some bashing and still some rubbing...as was going camping this weekend, did more bashing...result!! Fully loaded and on a spirited drive she never swore at me once     [attachment=16311] Wishes for more power...
		16-05-2014, 08:54 PM
		Great stuff mate   Its such a gut wrenching noise hearing rubbing. It just sounds like money being scraped away! Not had an issue with mine for months. Went on pug run, real gave it some beans and was scrubbing under hard cornering. Out comes the arch roller again I suppose! ![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg) Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
		16-05-2014, 09:22 PM
		Guna have to do something about the paint, I got it pretty warm but it still cracked. Once I get 21mm tbs in there it should be even less likely I hope! Wishes for more power...
		16-05-2014, 09:28 PM
		Thats the right attitude! lol If they don't fix it, get 23's :p ![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg) Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
		16-05-2014, 10:00 PM
		Looks good chap you been having fun with the arch roller don't think you can get away with out the paint cracking unless you very lucky
		16-05-2014, 10:13 PM
		Nope...heat gun, patience and a rubber mallet Is it best to cut away the lip and seal it or rub it down and stonechip it? Wishes for more power...
		19-05-2014, 06:59 AM
		God no.  Don't cut the lip it's structural
		19-05-2014, 09:55 AM
		Well, got to campsite in morthoe...via Porlock hill. Lots of 180off camber corners on 1:4 gradients.... Temp just kept rising till I pulled over at 110degrees. Dropped back to 77 then at next 1:4 went to 100. Been fine for rest of journey till at campsite it was warming up, fans came on slow (by themselves) at 80 though which I though was odd?! Wishes for more power...
		19-05-2014, 10:36 AM
		as you mentioned Porlock I thought of  '306 in the twistys...' it is a very good driving road. Car looking top notch
		20-05-2014, 08:28 AM
		Tiz an amazing driving road... Feels like it needs a TBodied 1600 106 rallye though...not a 2.1 cruiser loaded up with camping gear. Temp behaved itself later in the day....through traffic, went from 77-82-77again. Real odd   Wishes for more power...
		20-05-2014, 08:35 AM
		Some gunk in the coolant, is It worth dropping, flushing and refilling just in case - wouldn't want it to cause bigger issues    ![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg) the smokey old bus that sounds like a tractor...
		Been emptied and flushed not long ago. May do again soon though as matrix bleed showed gunk. Anyway...home again...540miles later...400miles since temp issue and all fine...gave it the beans, had slow traffic trawls on M5 and all sat on the temp where it should. Odd Here she is at the seaside... [attachment=16428] Wishes for more power...
		23-05-2014, 04:34 PM
		Do it just to be safe mate, put a hose pipe in the block, put heater matrix on hot and try and push the gunk out of the system before refilling    ![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg) the smokey old bus that sounds like a tractor...
		23-05-2014, 05:05 PM
		Yeah I know how to do a flush buddy!! And putting the matrix on hot/cold will make no difference as its always flowing on a 306...well, most pugs actually Wishes for more power...
		23-05-2014, 08:45 PM
		Throw a can of rad flush in too for good measure?
		23-05-2014, 09:03 PM
	 (23-05-2014, 05:05 PM)Piggy Wrote: putting the matrix on hot/cold will make no difference as its always flowing on a 306...well, most pugs actually I didn't know that, learn something new every day   ![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg) the smokey old bus that sounds like a tractor...
		24-05-2014, 02:55 PM
		Your thinking of the fords with those weird solenoid valve things in the heating circuit no? :p
		24-05-2014, 08:50 PM
	 (19-05-2014, 09:55 AM)Piggy Wrote: Well, got to campsite in morthoe...via Porlock hill. ouch! 110 . . . . that's fcuking shit up temps unless it was lying, hopefully you'll be ok . .
