	Threads: 1
 Car Model/Spec: 1999 306 Roland Garros 1.8
 Thanks: 0Given 0 thank(s) in 0 post(s)
		Hi there, greetings from Denmark
I have a 1999 Pug 306 Roland Garros i'm very happy to own it, but it just need a bit more power so i bought a Gti manifold from a scrapped 306 and i want to fit it on my car. For some reason i can't get to the old dirty and rusty manifold. I need some help, what can i do?
	Threads: 61
11 Location: Bury  St  Edmunds Suffolk
 Thanks: 2Given 41 thank(s) in 41 post(s)
		Okwhat is it gti,xsi,s16?
	Threads: 1
		 (14-04-2014, 05:44 PM)7057sam Wrote:  Okwhat is it gti,xsi,s16?
Do you mean the car or the manifold? The car has a 1.8 16v engine and the manifold is from a  306 gti 6.
	Threads: 448
51 Location: isle of wight
 Thanks: 17Given 18 thank(s) in 18 post(s)
		There is a guide in here somewhere. You say rusty manifold, the 1.8 should be plastic?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 236
36 Location: Stevenage
 Car Model/Spec: '01 HDi DTurbo
		The exhaust manifold I assume he means. The 1.8 XU7JP4 standard exhaust manifold wasn't built with performance in mind, it's just an unequal-length manifold designed to take up as little space as possible - and yes, they will corrode.
 I believe you're looking at a few bolts and some which are studs in the head.
 It's also worth noting that your standard exhaust system won't marry-up, since the GTi6 exhaust manifold is physically bigger / longer and reaches further back than the 1.8. Your current one will be too long.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
	Threads: 448
		Hahha that would make more sense! Didn't even think
	Threads: 1
		15-04-2014, 06:09 PM
(This post was last modified: 15-04-2014, 06:10 PM by Dg95pug306.)
		 (15-04-2014, 09:44 AM)C.A.R. Wrote:  The exhaust manifold I assume he means. The 1.8 XU7JP4 standard exhaust manifold wasn't built with performance in mind, it's just an unequal-length manifold designed to take up as little space as possible - and yes, they will corrode.
Yeah i mean the gti 6 exhaust manifold sorry.. I have tryed to see about if the manifold will fit straight over but it's too long in the end pipe, and omg (  ) there's no space at all to get the original manifold out. How can i get to the manifold? I've already got a sebring backbox on the car, removed  the spare tire and stuck a K&N panel filter in the airbox (I lose a lot of pulling power by a big air filter), what else can i do to upgrade my 306  ?
	Threads: 183
20 Location: eastwood/notts
 Thanks: 0Given 8 thank(s) in 8 post(s)
		Gti6 intake manifold
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 1
		Sounds difficult, what about the ecu? My old 306 1.4 burnt the cat inside because the ecu was overfuelling the engine..
	Threads: 236
		The Sagem ECU doesn't really like the GTI inlet manifold. What you end up with is much greater throttle response but I've had 2 1.8s and neither ran properly with the GTi6 bits because the ECU was holding it back. The second one I had even had GTi6 cams in it, but still didn't work properly.
 The exhaust manifold does make a marked difference in noise and there are possible gains higher up the revband, but looking back it really isn't worth the effort unless you go all-out.
	Threads: 1
		16-04-2014, 02:10 AM
(This post was last modified: 16-04-2014, 02:10 AM by Dg95pug306.)
		 (15-04-2014, 08:07 PM)C.A.R. Wrote:  The Sagem ECU doesn't really like the GTI inlet manifold. What you end up with is much greater throttle response but I've had 2 1.8s and neither ran properly with the GTi6 bits because the ECU was holding it back. The second one I had even had GTi6 cams in it, but still didn't work properly.
I don't want to fit a gti induction manifold then, i decided just to fit the gti 6 exhaust manifold to my car, i'm just stuck on how i get the old manifold off. Does the subframe need to be loosen or must the engine mounts need to be removed to push the engine forward?
	Threads: 236
		Both of those techniques work.
 Rotating the engine forward is 'easier' if you don't have the facility to raise the car up nice and high and drop the subframe down. You need to be very careful though, because from memory when you rock the engine forward it gets very close to the radiator. Get a block of wood between there to brace the engine against the slam panel rather than the more delicate radiator.
 And yes, it's still very, very tight and you will have a lot of fun loosening those nuts. It was recommended to me that you run the car for a while to heat the manifold up, but in the end I took mine to a mate who had a ramp in his garage and did most of the work for me!
	Threads: 448
		'6 intake manifold is easy to fit, I've got one sat here if you want it? All sensors and throttle body sat around.
 It's a bonus and most say that on the 1.8 it makes a difference, I've never had one so no idea, just fit the manifold, and do an ecu reset, by leaving battery disconnected for like 30mins
 The exhaust manifold, to do it you are gunna need a gti cat/decat too as the 1.8 is too long, easy way to gain acsess is too take the engine off the top engine mount and tilt the engine forward (after disconnecting the cat) it will give you more room to get to it.
 You may have to get a heat shield or wrap the manifold as the water pipes nearly touch it iirc
	Threads: 236
		Matt brings up a good point actually that's very easy to forget. The water pipes on the 1.8 are a different shape to those on a GTi6 and actually touch the manifold. There are a few solutions, you could fit GTi6 water pipes (bit of a PITA), you could cable-tie the heater pipes away from the manifold (surprisingly effective!) Or heat-wrap the heater pipes.
 The GTi6 also has a piece of tinfoil (ok, it's a heatshield) protecting the brake lines / bulkhead from the manifold heat.
	Threads: 1
		16-04-2014, 11:05 AM
(This post was last modified: 16-04-2014, 11:06 AM by Dg95pug306.)
		Thanks mates, i haven't tryed remove a subframe before so will try undo the engine mounts and get the engine forward to get to the manifold. I forgot that i have a Peformance chip from Celox (Ebay), does it harm the car if i install it?
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Don't install that chip. They are shite. They just make the ecu over fuel.
