12-03-2014, 02:38 PM
Just wondering what bulbs are used in the clock/temperature display in the centre console, mine are buggered!
Cheers, Phil
Cheers, Phil
Clock bulbs
Cheers, Phil
13-03-2014, 08:39 AM
They're the same bulbs that are used in behind the dash bud not sure what size they call them, you could change them for blue bulbs like mine. But make sure you remove the yellow film and replace with a white film ( behind the clock) avoid cheap ebay ones as they tend to stop working or start flickering after a short while
14-03-2014, 04:37 PM
Bump. Mine went after I installed a head unit. How do you get the clock out? Simply pry it out with a screwdriver?
14-03-2014, 06:31 PM
(14-03-2014, 04:37 PM)liam Wrote: Bump. Mine went after I installed a head unit. How do you get the clock out? Simply pry it out with a screwdriver? Simply remove the plastic facia around the clock display and you will see two torx screws. Remove them and unplug the wires going into the clock I did mine yesterday it's really easy
14-03-2014, 08:50 PM
(13-03-2014, 08:39 AM)Bnmtuning Wrote: They're the same bulbs that are used in behind the dash bud not sure what size they call them, you could change them for blue bulbs like mine. But make sure you remove the yellow film and replace with a white film ( behind the clock) avoid cheap ebay ones as they tend to stop working or start flickering after a short while You got a link for these blue bulbs? I've got them in mine but for some reason sometimes the one stays off -_-
14-03-2014, 08:52 PM
T5 wedge bulbs iirc
25-03-2014, 12:02 PM
Now I don't know what colour to go for xD
