05-03-2014, 12:19 PM
		Anyone tell me what differences there are between the 2ltr xsi and the 6 apart from the Maine and box lol
					Xsi v Gti
		05-03-2014, 01:42 PM
		Erm from what I can remember, plastic inlet manifold, smaller throttle body, slightly different head(?), gearbox, suspension, ecu
Current stable  '09 Mercedes E320cdi wagon '99 306 gti6
		05-03-2014, 02:40 PM
		XSi were 8v/16v S16 was the model up, with 5 speed GTi-6 was the S16 with a bit more power and a 6 speed gearbox
3 x Peugeot owner. 1996 106. 1996 306 D Turbo S. 1994 Mercedes Benz 320E. 1997 306 GLX. Subscribe! - https://www.youtube.com/user/TheADKJD/videos
		05-03-2014, 03:02 PM
		Xsi 16v is more similar to the gti6 than s16... S16 is essentially A 405 engine with a plastic manifold
		05-03-2014, 03:22 PM
(This post was last modified: 05-03-2014, 03:22 PM by powerandtorque.)
		XSi 16v is the 136hp XU10J4R engine GTi-6 is the 167hp XU10J4RS engine Whilst in theory the RS is a tuned version of the R, in reality it's easier listing what is the same between them - block, crank, sump and flywheel and a few sensors. Almost everything else is different - head, pistons, cams, valves, valve springs, manifolds, throttle body, injectors, fuel rail, ignition, loom, ECU to name but a few. The majority of the RS parts can be fitted to an R though, hence it being popular to fit the cams and manifolds and liberate a fair amount of power. The 1.8 16v (XU7JP4) is again a similar design and many of the top end and bolt-on parts can be moved across - it's alloy block and both smaler bore and lower capacity, and the head has inlet ports that are quite deliberately restrictive. Earlier S16 is the 2.0 Mi16 (XU10J4) engine which is pretty much an iron block version of the 1.9 Mi16 engine and has little in common with the later engines - head, cams, manifolds, pistons etc all different.
		05-03-2014, 04:18 PM
		XSi's are just a lazier, thirstier 1.8 tbh...
		05-03-2014, 04:51 PM
(This post was last modified: 05-03-2014, 04:57 PM by rocker8742.)
		Nice knowledge guys, any info about torsion bar size etc? Looking to buy one cheap at the weekend
		05-03-2014, 05:03 PM
		Both should be the same - 20mm torsion bars and 24mm anti-roll bar.
		05-03-2014, 06:31 PM
		GTi6 also has a higher perssure oil pump and a higher rev limit, 7500 on ph1 and 7250 on ph2/3
		06-03-2014, 09:36 AM
		In my experience the xsi is shit haha!,drained more fuel then my 6. I had the 2litre 8v xsi though
		06-03-2014, 10:13 AM
	 (05-03-2014, 06:31 PM)Dum-Dum Wrote: GTi6 also has a higher perssure oil pump Oil pump pressure is identical at 6 bar - whilst the pump casting is slightly different** they both use an identical relief spring (115711) and piston (113313) Indeed, as far as I'm aware, all the XU10 series engines - 8v and 16v - have 6 bar oil pumps fitted. ** - I've seen a few J4R's that have the RS pump as standard, so I think that despite what Servicebox says it was pot luck what pump was fitted to the J4R's.
		06-03-2014, 09:10 PM
		The suspension on the ph2/3 xsi is the same as the 6 , but has the 266mm calipers, & the engine drives very differently lol
