	Threads: 203
Car Model/Spec: Peugeot 306
		after a month rebuilding my car and after 100miles my gt15 shit it self and ran on its own oil lucky i jumped out off the car and blocked air intake straight away most off the oil is still in the block but a fair bit did come out the exhaust its a new engine job our is it just a new turbo
	Threads: 151
14
Car Model/Spec: 306 D-turbo
		only way to find out is strip engine and check for damage or put another turbo on and start it up see what its like
should be ok though if there is still oil in it.
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
Team Doesn't own a 306
	Threads: 226
24
Car Model/Spec: A3 TDi
		If theres still some in the sump and you shut it off before it did mega RPM i would of said new turbo and she'll be fine.
	Threads: 203
		about half full of oil wasnt limit bashing but was fairly high
	Threads: 203
		will have a look at the damage tommorow
	Threads: 226
24
		Christ that would be fine. Id ony worry if it had no oil or the revs went like 6k+
	Threads: 203
		better be our getting sledge hammer to it
	Threads: 33
Car Model/Spec: 306 D-turbo/306 Rallye
		All of my oil went down the exhaust, engine oil light on, the most horrendous diesel knock ive ever heard, stalled it in 5th, all i did was put a new turbo on and its still fine 30k later
Blaze '6 and Blaze D-turbo!
		Just make sure you clean out all the intercooler, inlet manifold and related piping - there will be oil left in it, start it after changing the turbo without cleaning it, and it'll blow up all the old oil straight into the engine - probably causing it even worse damage.
 (16-05-2016, 10:45 AM)Toms306 Wrote:  Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
