	Threads: 18
		Hi all just a quick question? I have a aftermarket stereo in my 306 it wont power up properly but will eject cd and if i press a button the time comes up. Any ideas what the problem is. It worked fine and ive tried another stereo that works and same problem. The only noise i get is the relys clicking alot
	Threads: 15
2
Car Model/Spec: blaze 6.. china dturbine
		Sounds like a bad earth or other dodgy connection ... :-)
	Threads: 581
195
		So i assume it doesn't turn on with the car but you can turn it on manually wether the cars running or not? If so, your shunt fuse is in the wrong position.
If it just doesn't turn on at all but still ejects CDs. Sounds like your switched live isn't connected properly.
	Threads: 18
		It wont power on at all. I did have the fan hooked to it. Could i usb burnt out a wire
	Threads: 61
4
	Given 6 thank(s) in 5 post(s)
		Is the memory wire the only one getting power then (allowing it to eject cd's)and It sounds to me the switched live isn't getting power atall.
	Threads: 18
		Sounds about right ive no way of testing which have power bar putting my tounge on it and hoping for the best haha
	Threads: 581
195
		The fan hooked on it? What fan? Have you checked your fuses?
	Threads: 18
		No fuses checked yet and engine fan wont kick in unless connected to battery or live so wired to stereo to turn on
	Threads: 581
195
		That just sounds like a huge bodge to me. I do hope you have just wired the relay activate cable to it and not the actual fan power cable otherwise it wouldn't surprise me if you have melted all the cabling!
	Threads: 581
195
		 (17-01-2014, 04:49 PM)sillywotsit1993 Wrote:  No fuses checked yet and engine fan wont kick in unless connected to battery or live so wired to stereo to turn on
 (17-01-2014, 04:58 PM)SRowell Wrote:   (17-01-2014, 04:45 PM)Niall Wrote:  The fan hooked on it? What fan? Have you checked your fuses?
+1 what fan? D:
errrr i wonder Sam?
	Threads: 18
		Turns out it was a fuse and also found out theres more fuses blown under the bonnet
	Threads: 18
		Its all repaired now no problems it was a temp fix to move it
