	Threads: 591
54
		27-12-2013, 10:32 PM
(This post was last modified: 27-12-2013, 10:32 PM by Piggy.)
		On here
Ebay
Scrapyard
And which fans?...are you sure its the fans, not a fuse or relay or sensor?
	Threads: 6
Car Model/Spec: Peugeot 306 1.8
		yea the motors have gone they were on constantly when i got the car
	Threads: 591
54
		Scrappy...fiver surely?
Or put up a wanted...I think I got some even...may have thrown them out to be honest!
	Threads: 386
87
		Can't cost much from a scrapyard.  I've never been able to sell fans when breaking cars, they just end up scrapped usually!
	Threads: 6
		ill have to see if i can find a scrapyard around here
	Threads: 386
87
		Autobreak in Colchester was pretty good, only one left that lets you walk around and get your own parts!
Or Whip St Motors near Claydon, but they don't let you walk around and charge quite a bit.
	Threads: 6
		ive been told whip street motors are ment to be good yea ill try that autobreak cheers
	Threads: 386
87
		I find whip st are just rip off merchants tbh lol....charge a lot for parts, pay out little for scrap!  But I must admit they've always had what I needed at short notice.
	Threads: 226
24
Car Model/Spec: A3 TDi
		I have some fans here, been sat outside for a while and i cant remember how short i cut the wires. But they're yours for cheap, just the postage will get you!
	Threads: 6
		im off to the scrapyard soon and wondering which fans will fit as he says he dosenty have a 2001 model in ? any help is much appreciated thanks
	Threads: 581
195
		Any set of double fans from a 306 will fit.
	Threads: 6
		anyone know how to unplug them they look like theres a specific way to disconnect the wires?
	Threads: 581
195
		Unscrew the lock ring and pull. Can be a right PITA to do. Check the pins for corrosion and clean up if needed.
	Threads: 6
		done all that however on the new one there are not the same amount of pins as the original im getting rather annoyed with it
	Threads: 6
		eventually got it all wired in but still nothing temp goes past 100 and dosent kick in removed the brown plug and still nothing :/
	Threads: 581
195
		Ah if you have removed the brown plug and your getting nothing then it needs a new fan controller which is fixed behind the bumper underneath the passengers headlight. Can pick them up for about £15 delivered. Im assuming you have checked all your fuses?
	Threads: 6
		28-12-2013, 08:40 PM
(This post was last modified: 28-12-2013, 08:50 PM by Ashwoody.)
		yea have checked all of the fuses going to double check it all tomorrow will have look to see if i can find that fan controller don't know what the guy did before i owned it but there are wires everywhere its a right bloody mess
do you mean the temp sensor?
