hdi to xud
was thinking of swapping engines, currently has a hdi engine, will a xantia d turbo engine fit straight in? what have i got to change? is it more effort than its worth?
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
Essentially its a straight swap especially if its a ph2 DTurbo with a bosch.
Youll need the engine and deciding which clutch and fly wheel your going to use (with the appropriate cable and selector arm)
A DT down pipe
Ph2 DTurbo clocks
DTurbo in tank pick up
and it all gets very easy (plug and play) if you have a ph2 DTurbo engine loom and just plug it into the NSF chassis leg
As for it its worth it that will be down to personal preference over the engines. Just bear in mind that you are likely to destroy any resale value of the car.
Another thread from a couple of days ago that might be useful: http://306oc.co.uk/forum/thread-19417.html
Basically if you buy a complete donor cars its easy, I managed to pick up a late p reg ph1 Dt for 200 quid so have everything needed
[Image: av5ym8.jpg]
