Van Options
I like the idea of having a van with a fairly simple Bosch/TD04L XUD in.
Whats the one to look for in terms of spec/simplicity of engine change?
I have a donor phase 1 D8A 306DTurbo with a T2 & bosch already on.
Berlingo?
Partner?
Any engine thats easiest to swap from (for speedo, rev counter etc)?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
old Dispatch . . . had a 1.9 nad in it i believe . .Smile
Just to clarify it doesn't have to be a massive van. Hence why I thought Berlingo/Partner would be a good choice. Much like the 306oc support wagon IIRC!?
S14 Zenki Build
XUD NAD was a stock engine in the partner, common as muck and it's already got the correct engine mounts and loom.
TU engined berlingo, cheap as chips because nobody wants them lol.
A low and boosted Citroen c15 would be win.
Nah you want an ldv pilot, rwd ftmfw.
This is the sort of thing I was thinking...
http://www.gumtree.com/p/cars-vans-motor...to-content
S14 Zenki Build
Why have you not bought it already?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(13-11-2013, 02:09 PM)Anton Wrote: Why have you not bought it already?
Wasn't expecting to dish out £200 on ARP studs this month..
S14 Zenki Build
Er, bargain much?
Especially as you'll be ditching the engine.
Get it bought!!
Theres no contact number so I've emailed them mine.
S14 Zenki Build
If I hadn't of put the XUD in the 206, I would of liked to put one in a Partner. High boosted LCV Wink
Viewing/buying the van tomorrow.
Whos keen to help me swap the 1.9TD in then? Big Grin
He said it smokes white constantly, he's been told its an injector problem.
S14 Zenki Build
(13-11-2013, 03:47 PM)silverzx Wrote: He said it smokes white constantly, he's been told its an injector problem.
just needs a good old fashion drive around the block....at high rpm...
Or a 75 miles / 2 hour 20 minute A/B road bash all the way home. Tongue
Not that it matters as the 1.9TD lump would be going in!
What suspension do these use? Same strut assembly as a 306?
Torsion bar on the rear?
S14 Zenki Build
Need i say any more trent???? get on it!!!
Front end is 306 suspension on a Zx estates chassis it's around an inch narrower at strut tops. Uses 405/206 style rear beam. Fair few bits need swooping from the 306 to make it fit
www.prestige-auto-care.co.uk
305 van would be win
I hope this turns into a project thread!
it literally IS a 405 rear beam on these, as is the Xsara picasso...
front end as mentioned from bulkhead forwards is all 306.
engine wise it'll drop straight in.
Decided to give this van a miss.
- 100 miles / 2:20 hour away.
- Long list of MOT advisories from last year.
- Higher tax bracket (£215 year despite being 51 plate)
- Zero service history (bar the clutch/gearbox reciept which is worthless)
- Struggling to find a lift.
Turns out a friend of mines father just scrapped a mint Berlingo for £120 that he's owned for 12 years, gutted I missed it!
I'll keep an eye out locally but for now this is going under the carpet.. Sad
S14 Zenki Build
I still like the idea of a Dispatch with a high-boost XUD in it. Big Grin
[Image: MIRKxNP.jpg]
