	Threads: 3
		EVENING ALL, I PICKED UP A SET OF INJECTORS TODAY ON THE WAY HOME I WENT MOTOR FACTORS TO GET INJECTOR SOCKET AND WAS TOLD, DO'S THE INJECTORS MATCH UP WITH THE PUMP SO HE SAID LUCAS INJECTORS WITH LUCAS PUMP, IM CONFUSED CAN SOMEBODY HELP PLEASE.
	Threads: 142
58
Car Model/Spec: E46 BMW 320d
		Again with the caps?
What fuel pump have you got? If you don't know, put a pic of your engine bay up on here, and we'll tell you. As long as you take caps lock off. It's just not necessary.
	Threads: 71
4
Car Model/Spec: 205 dt
		matching them up would be best, but will run either way don't worry about it
	Threads: 3
		HI SORRY ABOUT THE CAPS THE PUMP I GOT IS A DELFI I BELEAVE ITS A DW8 ENGINE
	Threads: 71
4
		and still in caps ......
wron section then you don't own an xud
	Threads: 3
		29-10-2013, 08:18 PM
(This post was last modified: 29-10-2013, 08:37 PM by vanman.)
		hi joe so a DELPHI pump will work with well on the injectors i got on the side is lcr type but on my injectors 1 has a wire coming form it ?
hi joe but there's not a dw8 section dw10,should i be there im new to all this.
