	Threads: 47
Car Model/Spec: 2001 lx hdi estate
		Hi all.   Have posted a few words in the past.  Can anyone advise re hdi running temperature.  I have had a new radiator fitted( old one fecked) and now temp is running at 89 degrees constantly even with heater running.   Previously ran at a constant 78degrees, could it be the thermostat that is not opening and closing properly anymore.   Will this highish temp cause problems re head warping.
Your suggestions/cure would be appreciated.
    Cheers.....not so happypug.
	Threads: 9
Car Model/Spec: 306 hdi
		My car sits at about 80c I think that is normal for hdi from what I have read and seen,
Try thermostat see if that helps.
	Threads: 39
Car Model/Spec: P2 Dturbo
		sounds like it needs bleeding
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
	Threads: 226
24
Car Model/Spec: A3 TDi
		Are the heaters hot? Is the rad getting hot?
		As others have said, check it's bled and if the rad gets hot fairly evenly. Failing that it sounds like a new stat, you can check yours in a cup of hot water, opens at 84 so should pop when you cover it in boiling water and close about a minute later.
