	Threads: 39
4
Car Model/Spec: P2 Dturbo
		Rightt bit of a weird one
the panel on the back of the car that the "peugeot" and "306" badge are on under the boot is this actualy a part of the chassis or can it be removed easily? reason i ask is mine is in very bad condition and very badly chipped/repaired on one side
cheersssssssssssssss
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
	Threads: 151
14
Car Model/Spec: 306 D-turbo
		The bit below the lights and the boot lid
No it Dosent come off, I say it Dosent come off anything can be persuaded with a grinder
It's part of the shell unfortunatley
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
Team Doesn't own a 306
	Threads: 39
4
		brilliant wonder how i am going to repair it then lol
	Threads: 39
4
		will do once i leave work at 5:30
	Threads: 581
195
		Its not part of the shell but its not really easy to remove. You need to drill out loads of spot welds behind the bumper and on the boot lid lip and break the sealant where it joins the rear quarter panels then it will come off. A new genuine one from pug is actually very cheap apparently!
Edit: Part number 7243 84 and its £47.53
	Threads: 39
4
		 (13-09-2013, 04:02 PM)Niall Wrote:  Its not part of the shell but its not really easy to remove. You need to drill out loads of spot welds behind the bumper and on the boot lid lip and break the sealant where it joins the rear quarter panels then it will come off. A new genuine one from pug is actually very cheap apparently!
ah thanks Niall
 how do you search for parts by number online?
And I think ill probably try and repair it first of all with some filler and sand it down to try and make it look even if it turns out shit ill have to bite the bullet and try and fit one. ill post a pic up of it in a bit and to get some opinions
im going to scrappy tomorrow so may take a look at a 306 without the rear bumper and see where it attaches
	Threads: 581
195
	Threads: 39
4
		awesome thanks Niall
here is a couple pics of the damage not quite sure how this has happened
![[Image: badge2_zpsddf37a52.jpg]](http://i467.photobucket.com/albums/rr35/adz452/badge2_zpsddf37a52.jpg)
![[Image: badge1_zpsf18339c7.jpg]](http://i467.photobucket.com/albums/rr35/adz452/badge1_zpsf18339c7.jpg)
	Threads: 78
49
		Been damaged before and badly filled... If you were to redo it properly it would look a lot better, can't see it being worth the hassle to replace when it would need painting anyway.
Are those tights...?
	Threads: 39
4
		yeah ill sand it back and try and repair it myself cant look any worse than it does now.
and tights? i guess you mean the lights and no its flyeye/spivision
	Threads: 39
4
		took the badge off today to see the extent of the damage who ever has repaired this has done a terrible job with filler its all flaky and uneven :/
never really undertaken any bodywork repairs before any suggestions on how i go about sorting this? any ideas appreciated thanks
![[Image: IMG_2414_zps9bb08ffc.jpg]](http://i467.photobucket.com/albums/rr35/adz452/IMG_2414_zps9bb08ffc.jpg)
	Threads: 39
4
		awesome thanks for that piggy ill take a look.
is it just my work PC or do the pictures in that thread not work anymore?
Thanks
	Threads: 476
81
Car Model/Spec: 306 Rallye
		jesus D: even i could do better than that! shouldnt be too much work and you cant do any worse! good luck.
