	Threads: 12
 Car Model/Spec: Peugeot 306 1.8 16v Meridian
		Hi everyone as per my thread below. I believe it was my cambelt that had snapped yesterday :/So was thinking instead of shelling out to repair that one. I was thinking of dropping in a gti 6 engine.
 Any advice. Tips. Help. Pros. Cons etc would be very helpful and maybe a link to a conversion already done on here?
 Thankyou in advance
	Threads: 236
36 Location: Stevenage
		Easier to buy a whole GTi6 as a donor for a start, as you'll need a lot of parts and bits you probably won't think of immediately.
 I would say cheaper/easier to buy a GTi6 and have done with it, but notice you have a 5-door.
 You'll need to swap a lot of it over and it's worthwhile upgrading the brakes and suspension all at once too. If 5 doors aren't necessary then it's a bit of a pointless conversion IMO.
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		yeh its a bit of a pointless conversion. itd be cheaper and better just to buy a 6. then you get the thicker torsion bars, bigger brakes, little bits of trim, 6 speed box, and the engine most importantly!
	Threads: 82
27 Location: North Somerset
 Thanks: 6Given 22 thank(s) in 22 post(s)
		Tbh, CARs right.. you're looking at £350'ish for everything you need engine wise.. plus suspension & brakes etc.. better off just buying a '6..
	Threads: 12
		I need the 5 doors thought, I regularly take my mother in law to hospital appointments so its easier to get her the back of the car.
Could anyone list the major points I'd need to make it work
For example.
Engine
Engine loom etc
Thanks
		Engine, loom, ecu, suspension, brakes, dash clocks, gearbox, clutch, 6 speed gear shifter is what I can think of so far...
	Threads: 12
		16-09-2013, 10:40 AM
(This post was last modified: 16-09-2013, 10:41 AM by Keeno123.)
		Would be using my original gearbox so what would that eliminate?
 Could use my original clutch?
	Threads: 31
4 Location: directly above the center of the earth
 Car Model/Spec: tu5 bitza/cherry dt
 Thanks: 2Given 5 thank(s) in 5 post(s)
		Box shifter and rack if I remember rightly
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		just find a gti6 with mot ending or similar...be 300/400quid.
 get all the bits you need. sell the rest as spares. scrap the shell and it will make a lot of the money back
	Threads: 208
60 Location: Wiltshire
 Thanks: 1Given 5 thank(s) in 5 post(s)
		I think you would be better off and easier to use the 6 box .
 But as said buy a whole gti6 would be the quicker easier way to go about it. It could end taking alot of time and hassle fecking about finding all the parts seperate
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg) Member of 99% warning or your nothing club!
	Threads: 12
		Cambelts snapped    how do I know? It's in my hands lol
I stopped pretty much straight away.
Any glimmer of a hope it might be ok?
Thanks
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Could bang a new head on it and it should be ok but no guarantees.
	Threads: 31
		Be a good excuse to put a 6 head on it with management and manifolds
		^^^thats not a bad shout...save a bit of weight too!
	Threads: 12
		 (16-09-2013, 05:01 PM)Piggy Wrote:  ^^^thats not a bad shout...save a bit of weight too!
Any further more in depth how to? I'm a complete novice as you can probably tell lol
	Threads: 31
		16-09-2013, 09:47 PM
(This post was last modified: 16-09-2013, 09:48 PM by 306Dan.)
		From what I understand of the conversion the head bolts on no probs, then you run 6 manifolds injectors fuel rail and ecu, unsure on loom atm, a few people on here have done it ill track down the threads and link them
		dont put a 5 speed gearbox on a 6. the gearbox is half the fun!
	Threads: 12
		Found an engine same as my original one. 86k - 10k less than my original engine, picked it up for £50 out of running car, hopefully transplanting it tomorrow
