24-08-2013, 09:03 AM
		Think I'm goin to attempt it 2day how easy or hard is it to do any tips and any do's or don't s cus it looks awkward it's got power steering and hasn't got a/c if that makes a difference cheers
					Changing alternator on 1.9td
		24-08-2013, 09:16 AM
		jack up o/s and secure.
remove splash guard take tension off belt. remove belt take positive terminal of battery off. undo the 8/10mm and 13mm nuts on the alternator terminals and remove wiring undo the two bolts, sometimes three, on the alternator. remove alternator. I have a few good alternators for cheap if you need a nee one Wishes for more power...
		24-08-2013, 09:19 AM
		Cheers for ya help mines realy noisy so changing it cus sounds like a nail when I'm driving around I brought a second hand alternator of eBay for £10 will see if its any good abit l8r if its a crap 1 will let ya know and prob have 1 off ya cheers
		24-08-2013, 09:30 AM
		Piggy has it pretty spot on there. Also be careful of belt tension when refitting. I was told that when you push it on an unsupported part it should move roughly 5mm if it's right.
		24-08-2013, 10:01 AM
		on the longest part of the belt when tensioned, you should be able to twist the belt about 90degrees with your fingers
		24-08-2013, 11:22 AM
		Do u take tension off the belt by loosening the Allen key bolt that you can see underneath the car is that the tensioner
		24-08-2013, 11:37 AM
		yes.
but first undo the two allen head bolts holding the tensioner secure
		24-08-2013, 11:38 AM
		Ok cheers thanks for ya help
		24-08-2013, 11:41 AM
		one is 1/3 way up side of tensioner.
the other in centre of tensioner pulley, sometimes has a plastic cover over it Wishes for more power...
		24-08-2013, 03:35 PM
		Changed alternator wasn't to much hastle to be fare but then realised my problem wasn't the alternator but the tensioner so changed that and loads quieter and while I had the car on axle stands I gave it a little more boost
		31-08-2013, 11:41 AM
		i actually found it easier to undo the 2 16mm bolts and removing the oil filter and sliding it out that way, took 15mins
