10-07-2013, 10:01 AM
Basically as per title, will a xud clutch work in a hdi box? been offered a xud paddle?
Silver Five Door D-Tuurbo'! More Doors More Whores y0!
XUD Clutch In HDI?
10-07-2013, 10:04 AM
It will work yes, you need to nick a few bits from an XUD gearbox to change it from a push to a pull type mechanism though
Would you be nice enough to give me a list of what i need?
10-07-2013, 10:11 AM
Sorry mate, cannot remember off the top of my head I'm afraid, sure someone else will be along shortly though
Okay bud no problemo! would it be easier to just go xud box?
10-07-2013, 10:14 AM
Depends what you're after really, if you did swap to a XUD box it would make it a bit revvier as the ratios are longer on a HDi gearbox..
10-07-2013, 10:15 AM
& iirc that's just a straight swap no?
10-07-2013, 10:19 AM
Hdi is push clutch, xud is pull...
You have to convert between the two, so you need a 2.0 petrol flywheel as they have the reluctor ring needed for a HDi but are pull style... You also need the fork out of any pull style clutch gearbox...
(This post was last modified: 10-07-2013, 10:20 AM by Midnightclub.)
No, you'd need the flywheel from a GTi6 too iirc
EDIT: What he said ^^
10-07-2013, 10:59 AM
Yep as ruan says you need
Flywheel off an XSi/GTi6 The fork and arm through the gearbox DT Clutch cable Cable bracket for the gearbox New Flywheel bolts Plus obviously the clutch and the release bearing. Its an easy enough swap but you wont be able to lock the flywheel to do a cambelt change as the petrol flywheel dosent have the locking hole. |
