	Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
		Hi guys bit of a problem. Was out earlier in the car with my mate. Thought I'd show him some boost so clutched the car to get it on boost them it cut out. Started It the revs would only start when the pedal was near the floor. Then it wouldn't start, ran out of derv so filled her up starts better but no revs. I've been trying to adjust the throttle arm but to tired to think after doing a 16hr shift then at it again today working and doing axle. If anyone can help please say. Debating on selling the cabby and the derv now
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
	Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
	Given 1 thank(s) in 1 post(s)
		Checked cable? tbh iv never really liked your pump there's something just not right you've slways had problems with it. I highly doubt the arm has slipped unless the splines on the arm are shagged or the lock nut has come loose and popped the arm off the splines. A possibilty is the gov cradle could have snapped with the harsh launching. Could be anything. Standard pump and a couple of hours and itl be a different car if you came back to me
www.prestige-auto-care.co.uk
	Threads: 170
5
		Can't see it being cable. Guna have to get another pump. Don't suppose you have one about do you?
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
5
		02-06-2013, 12:50 PM
(This post was last modified: 02-06-2013, 12:52 PM by karl1989.)
		Took the top of the pump off. No gov to be seen looked around and can't see it anywhere :confused:
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 226
24
Car Model/Spec: A3 TDi
		Its probably been eaten by your pump. If thats the case it could of made it into your injectors and allsorts. Bad day to be you.
	Threads: 170
5
		It still starts fine. Need a another pump asap
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 94
7
Car Model/Spec: 205 coming soon
		Think cj may have a pump not sure though
Official Team Go-NAD fan club
	Threads: 41
12
Car Model/Spec: Dtractor
	Given 6 thank(s) in 6 post(s)
		Your gov is gone??? Lol wtf
	Threads: 591
54
		woh...thats a new one...epic epic fail
	Threads: 119
15
		It was all in the bottom of the pump and unsurprisingly intact!
	Threads: 119
15
		It's like the cir Clip had pinged off but I'd goved it last year so if that was the problem then it would have happened sooner all the gov bits are reusable not damaged including the circlip so there wasn't any stress. Karl had the then top half off the week before but was able to drive it as usual. Iv still got the bottom half of the pump the governor pin is still floating about in it! Will dig it out when I can be arsed!
	Threads: 170
5
		Still got most of the bits for another gov
. New pump is good just got to tweak it more
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 226
24
		Thats amazing that it survived!
