	Threads: 374
38 Location: Isle of Wight
 Car Model/Spec: GTI 6
 Thanks: 8Given 16 thank(s) in 14 post(s)
		Anyone got any idea how this shaft comes out.
 I've removed the 2, 11mm bolts on the engine mount - pulled hard, nothing.
 I've tried removing the bracket at the gearbox where the speedo cable(?) plugs into, levered and still nothing.
 I've tried removing the engine mount altogether and pulling, again, nothing.
 Any ideas?
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Theres 3 bolts on the rear engine mount
	Threads: 374
		 (02-04-2013, 05:51 PM)Niall Wrote:  Theres 3 bolts on the rear engine mount
sorry, i mean, i removed the 2, 11mm bolts holding the shaft on the mount, and following this, i further removed the entire mount/bracket (17mm iirc?)
but yeh, the lower mount is completely lose and seperated from the block
	Threads: 386
87 Location: Suffolk
 Thanks: 1Given 118 thank(s) in 117 post(s)
		02-04-2013, 06:01 PM
(This post was last modified: 02-04-2013, 06:03 PM by Toms306.)
		A big f*cking hammer.  Honestly, it will be seized in really tight.  Theres nothing else holding it except those little odd shape 11mm bolts.
 On the 3 HDi ones I've removed so far they've all needed a lot of whacking....
	Threads: 374
		 (02-04-2013, 06:01 PM)Toms306 Wrote:  A big f*cking hammer.  Honestly, it will be seized in really tight.
but where exactly am i wacking?
	Threads: 386
		02-04-2013, 06:04 PM
(This post was last modified: 02-04-2013, 06:05 PM by Toms306.)
		The shaft has a bearing ring around it.  Whack this ring out of the mount, towards the wheel end of the shaft obviously.  You'll need a chisel or crowbar to focus the hammer force just on the ring.
	Threads: 374
		 (02-04-2013, 06:04 PM)Toms306 Wrote:  The shaft has a bearing ring around it.  Whack this ring out of the mount, towards the wheel end of the shaft obviously.
ok, but then surely that'll just free up tje driveshaft from the mount, not the gearbox?
	Threads: 386
		02-04-2013, 06:07 PM
(This post was last modified: 02-04-2013, 06:11 PM by Toms306.)
		Nothing holds it in the gearbox.  Its just the fact its stuck in the mount that stops it coming out of the 'box itself.
Oh hang on....are you saying the mount is completely free now (not attached to anything except the shaft) but the shaft is still stuck in the box?
If so I've no idea as theres nothing holding it in the box!!     I thought you were trying to get it out of the mount which is the usual issue lol.
	Threads: 374
		 (02-04-2013, 06:07 PM)Toms306 Wrote:  Nothing holds it in the gearbox.  Its just the fact its stuck in the mount that stops it coming out of the 'box itself.
hmm ok, this confuses me - i've disconnected the mount from the block, and taken a hammer to the mount, but nothing, no shaft movement
	Threads: 151
14 Location: Rotherham
 Car Model/Spec: 306 D-turbo
 Thanks: 1Given 0 thank(s) in 0 post(s)
		The mount is completely off the block? And the shaft is out of the hub? If so mtfu and give it a whack
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
Team Doesn't own a 306
	Threads: 386
		Hmm.
And the shafts got space around it to come out yeah?  Not caught on something daft?
	Threads: 13
 Car Model/Spec: ph2 dturbo
 Thanks: 0Given 0 thank(s) in 0 post(s)
		I used a ball joint splitter on the bearing to knock it out. 2 hits and came out piece a piss. Puts pressure on both sides then
	Threads: 374
		 (02-04-2013, 06:14 PM)Danny2009 Wrote:  The mount is completely off the block? And the shaft is out of the hub? If so mtfu and give it a whack
Shaft is still in tbhe hub, merely for convenience and i dont fancy rounding and threads hitting the shaft out, theres enough play to get the shaft out, thats for sure - it's all going back in eventually
  (02-04-2013, 06:15 PM)Toms306 Wrote:  Hmm.
space, yep as said in reply to danny ^^^
Nope - not from what i can see, i've stopped for the day as its getting cold and dark - will have another look tomorrow for sure.
	Threads: 386
		I assume you've popped the bottom ball joint off then.
	Threads: 374
		 (02-04-2013, 06:21 PM)Toms306 Wrote:  I assume you've popped the bottom ball joint off then.
lol yes its all free
	Threads: 386
		Haha, thought I'd better check just incase...
I will say though, you'll wish you'd just undone the hub nut.  It took us ages to remove the shaft on rowells without removing the hub nut.  Took about 10 mins to remove mine last week, including hub nut removal....
The only suggestion I can think of is hitting it through from the NS shaft hole with a long but fairly thin bar if thats possible.
	Threads: 151
		Take the shaft out the hub and it will come out with a good pull then, don't struggle just get it out the hub
	Threads: 374
		 (02-04-2013, 06:46 PM)Danny2009 Wrote:  Take the shaft out the hub and it will come out with a good pull then, don't struggle just get it out the hub
im just worried about damaging the boots?
	Threads: 183
20 Location: eastwood/notts
 Thanks: 0Given 8 thank(s) in 8 post(s)
		Iirc didnt this one twist a little first then pull out...
 Positive one of my driveshafts twisted out first
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 591
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		defo get it out the hub...have one guy holding tension on the shaft (pulling a bit)
 then wack it!!!
	Threads: 151
		Hold the bracket and tug that you will be fine
	Threads: 374
		hmm ok, cheeers for the info - i'll have another bash tomorrow
	Threads: 386
		Yeah as others have said....have a good tug on your shaft and it'll come....
	Threads: 41
12 Location: Midlands
 Car Model/Spec: Dtractor
 Thanks: 0Given 6 thank(s) in 6 post(s)
		Smash the rear engine mount off the shaft first.
	Threads: 16
0 Location: Meath
 Car Model/Spec: 406TD/XUD Corolla/lolvan
 Thanks: 0Given 1 thank(s) in 1 post(s)
		02-04-2013, 10:53 PM
(This post was last modified: 02-04-2013, 10:53 PM by Mal.)
		Assuming you're on about this boyo ![[Image: Image2720_zps55a67598.jpg]](http://i1225.photobucket.com/albums/ee388/humbrol/Image2720_zps55a67598.jpg)
Bolt the mount to the engine, plusgas the bearing, leave for a while.
Then get a block of wood, put it to the inner shaft's cup and smash it with a hammer. Have someone hold up the outer shaft as you do this. Mind the dust guard as you take the shaft out fully
Ta-da!
	Threads: 198
135 Location: Not near you
		Apart from making sure it's not in gear and pulling the driveshaft perfectly straight there should be nothing holding it in the gearbox.
 Personally i'd have thought it would be easier to do it with the mount still attached so you could use two hands to batter the shaft out..?
	Threads: 226
24 Location: Cornwall
 Car Model/Spec: A3 TDi
		Get a bar and lever it out, Or like 2 posts above block of wood on the cup and whack it.
	Threads: 374
		So finally - resolved, well as much as possible.
Ended up taking the engine out WITH the shaft attached - max came round, again, he was stunned it wasnt shifting.
Engine came out, eventually from underneath the car
Popped the engine on it's back, bracket meet sledgehammer, sledgehammer meet bracket. HUGE hit, nothing... again X20 and we got a slight movement. 5 minutes of smashing and eventually the shaft came out. the speedo had completly fallen apart. something along the line had seized the shaft up. Bought a new one, £44 picked up tomorrow.
So no, connor, spellowe and all the haterz, i'm not that  special.      <--- deserved popcorn
	Threads: 198
		 (03-04-2013, 08:23 PM)ginge191 Wrote:  So finally - resolved, well as much as possible.
Wait.. what?
The one time i've ever tried to have a valid input in one of your threads and you moan like a hissy bitch
I shall not bother in future
	Threads: 374
		03-04-2013, 09:27 PM
(This post was last modified: 03-04-2013, 09:29 PM by ginge191.)
		Oh c'mon Chris, don't cry
And I apologise, I think I saw Connor on another thread dissin' and rounded you in that, assuming usual spellowe posted
