why??
Is my Dt doing this then??
Iv took all the cambelt casing off yesterday locked the cam & pump in all good , took the starter off locked the fly in , so all that lines up and locks off , now there is no slack between the cranck & pump also now slack between the pump and cam so this would suggest the timing is all correct. and i can i retard & advance the pump as far as it will allow yet the result is the same , This >>>
http://www.youtube.com/watch?v=9U6hUWMsa-c
Any ideas???? surly air in the fuel lines would couse it to run this bad?
I'd just try loads of different positions with the pump. Mine runs like this in anything but its optimum position.
[Image: 20120704_212316.jpg]
Sounds fairly buggered. :/
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(01-04-2013, 12:34 PM)Ben Wrote: I'd just try loads of different positions with the pump. Mine runs like this in anything but its optimum position.
Iv been doing this on my own so its been loosen move it, start the car, turn it off , repeat several times, maybe need to get some one over so i can hold on to it and adjust whilst running,
Is your this bad it you adv/ret the pump out of optimum posision?
(01-04-2013, 12:41 PM)silverzx Wrote: Sounds fairly buggered. :/
This is the lump from my silver DT and was epicly sweet runner before i took it out
sounds like its missing!.
Thats sounds like its running on three cylinders, while its running loosen slightly the injector pipes one at a time to see which cylinder isnt working and work from there.
good shout lads i shal investergate when iv got the turbo oil feed back on
Fuel filter. My car was off the road for 6 months due to the same problem. I even made a thread about the ordeal!
Pretty fresh filter plus it ran fine on the same filter with the lucus :/
