	Threads: 96
		Right I have a leak of some sort it's not oil as its bit black it's kinda clear as far as I can make out.
its coming from the engine bay area but all my fluid levels seem ok, it's a funky smelling fluid, I can only think if either brake fluid or power steering fluid or gearbox ??
I can't see where it's coming from. The car is very low and ive buckled a few  bolts that hang low could I have cAught a pipe ?? Or punctured something metal any ideas welcome as I just can't see anything :-(
	Threads: 96
		This can be removed by admin had a little look and it looks like a gearbox leak  :-(
	Threads: 110
20
		If its gearbox good chance it will be drive shaft oil seals
	Threads: 62
10
		Is not black? Gearbox oil will be black and stinks of fish!
HDi Owner for 200k/9 years
	Threads: 96
		It's leaking from passenger drive shaft seal its a tiny of green/ black
	Threads: 150
14
Car Model/Spec: 306 HDI
		You would know if it's gearbox oil, f*cking rank stuff!
Place a bit of cardboard under the bay?
Is it after a run or all the time?
![[Image: 306ocsig_edited-1-1.jpg]](http://i1204.photobucket.com/albums/bb416/declantg/306ocsig_edited-1-1.jpg)
306 HDI, soon to be XUD
	Threads: 56
19
Car Model/Spec: Moonstone HDi
		Gearbox oil smells like celery
	Threads: 96
		31-03-2013, 03:15 PM
(This post was last modified: 31-03-2013, 03:16 PM by Jukie88.)
		Slowly leaks all the time it looks clear but had a slight greeny yellow tinge to it and yep it stinks and doesn't taste very nice :-( got a mouth full when I prodded the rubber seal on the driveshaft it's loose and looks like that's here it's coming from
	Threads: 56
19
		Think the seals are about a tenner each and are an easy job
	Threads: 110
20
		May as well do both and change all the oil
