20-03-2013, 05:17 PM
		Is the 110 hdi 406 turbo any different from the 306 hdi turbo ??
					Peugeot 406 turbo ??
		20-03-2013, 05:21 PM
		Pretty sure they have an intercooler and I would guess they are set up slightly different or mapped different
		20-03-2013, 05:28 PM
		I mean the actual turbo unit fella :-) just wondered as they run 110 bhp wondered of its a slightly better Built turbo
		20-03-2013, 05:46 PM
		Ah right sorry. I ain't sure on that but I reckon it prob be the same and as I said earlier maybe it's mapped different to get the extra 20bhp
		20-03-2013, 05:55 PM
		The only difference is the intercooler and map change
		20-03-2013, 05:57 PM
		Isn't the 110 turbo controlled by the ECU and not mechanical like ours?
		Cool beans I'm just looking for a Easy turbo upgrade and want something that will  bolt straight on but is more worthwhile mapping the the original turbo
		20-03-2013, 06:14 PM
(This post was last modified: 20-03-2013, 06:14 PM by londondan86.)
		20-03-2013, 06:26 PM
		There is pretty much feck all that bolts straight on tbh.
		21-03-2013, 07:09 AM
		I've touched on the subject before and got pretty much the same answer apparently some sort of van has a bolt on but can I hell find it :-( does anywhere/ anyone make adapter plates ?? As I'm really not that mechanically Inclined ??
		21-03-2013, 07:38 AM
	 (21-03-2013, 07:09 AM)Jukie88 Wrote: I've touched on the subject before and got pretty much the same answer apparently some sort of van has a bolt on but can I hell find it :-( does anywhere/ anyone make adapter plates ?? As I'm really not that mechanically Inclined ?? There's nothing that bolts on AFAIK, you'll probably find your local engineering place will make adapter plates. Welding and fabrication projects undertaken, contact me for more information.
		21-03-2013, 07:44 AM
	 (20-03-2013, 06:14 PM)londondan86 Wrote:(20-03-2013, 05:57 PM)DeeTurbo Wrote: Isn't the 110 turbo controlled by the ECU and not mechanical like ours? The 2.2 has a small VNT I think, ecu controlled and not particularly strong especially after remapping to 190bhp.... They tend to last about 6 months tops before sputtering oil and dying. The 110 I'm pretty sure has the same turbo as the 306 hdi but slight remap, not even into stage 1 territory yet with that.
		21-03-2013, 10:59 AM
		The 110 has an intercooler and different mapping, I think the turbo is different, its vacuum controlled by the ECU though
	 ![[Image: Ty8kl7b.jpg]](https://i.imgur.com/Ty8kl7b.jpg)
		21-03-2013, 02:39 PM
		110 is solenoid controlled with vacuum vs standard wastegate on the 90. 2.2 HDI uses a VGT turbo (Different to a VNT...)
		21-03-2013, 05:43 PM
