	Threads: 591
54
		welcome...
save up for a headgasket would be a good start....
	Threads: 87
48
		strip it mate, not a lot else to be done without a fair bit of knowledge  . .
	Threads: 591
54
		yeah loose weight, improve handling via light wheels, tyres and suspension upgrades...you wont get much from the 1.4
	Threads: 5
Car Model/Spec: 1.4mpi 306
		Yeah so I think I might go with strip the whole car out upgrade the handaling and exhauast system from the manifold back and have good air intake and that should do I think anyone recomend a good suspension/handling upgrades? And performance upgrads ?
	Threads: 591
54
		11-03-2013, 11:14 PM
(This post was last modified: 11-03-2013, 11:15 PM by Piggy.)
		you may lose your torque band if you freeflow the exhaust too much on the 1.4
cheap options for dampers and springs are out there...as said, gti beam, struts, brakes all cheap found second hand
and gti ARB and a strut brace upper and lower
	Threads: 591
54
		you'll want some diff springs for the front....but they cheap enough
	Threads: 226
24
Car Model/Spec: A3 TDi
		A damn good service. You wont get much out of that little engine but the best way is to make sure its perfectly healthy and making as much power as it can. Could always put throttle bodies on it for lols, it would definately draw alot of attention :p
