	Threads: 448
51
		Ecu reset my friend. Mine did the same, disconnect the battery for half hour and see what happens
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 448
51
		03-03-2013, 10:40 AM
(This post was last modified: 03-03-2013, 10:43 AM by Matt.)
		Mine had Similar symptoms too yours. It's all sealing right? What condition the injectors in?
Also whip the sensors out and give a clean. Guessing its the same manifold for the 1.8? Could be we're it was stood things have got a little dry?
	Threads: 169
91
		Fair play, ill try the battery off for a little longer. The map sensor was the existing one, other than that they're all from the 1.8. Ill give them a clean. Cheers bro
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)
	Threads: 130
82
Car Model/Spec: 106 GO-NAD
		Try using all the xsi sensors? Different management so might be different resistance values, so the ecu might be getting the wrong info
	Threads: 169
91
		Right, put the original inlet back on:
-Fuel is coming from all 4 injectors, so i no longer believe i have nicked an injector wire somewhere.
-It still wouldn't run until I unplugged all of the manifold sensors. It then ran at 3k
-Systematically plugged them all back in, it then only dropped and stalled when the TPS was plugged back in.
-This TPS was working fine before removal, so whats the odds of both this one, and the one on the '6 mani being the issue?
	Threads: 58
Car Model/Spec: Loads
	Given 9 thank(s) in 9 post(s)
		Swap all the Injectors, Map sensor over onto the GTi 6 inlet, Inc Idle valve
	Threads: 169
91
		This is doing my nut in now lol
Ive swapped every sensor from the original inlet, no luck.
Put sensors from GTI inlet on standard mani and it runs fine.
Dafuq?! Maybe the gods of the 306 are telling me not to fit it...
