	Threads: 343
 15
	Given 3 thank(s) in 3 post(s)
		Well as above im getting veg in 20 liters, i carnt hold the funnel and hold 20 liters of veg in one go i have to keep getting people to help also seems to take ages to pour the veg in though the funnel got to be a quicker way? .
So whats the best way to get it in my tank need something that will hold its self while im pouring and be big enough bore to flow quick but at same time enough space round the filler neck to let air out as im putting it in.
No daft answers please all though im sure i will get some one say just pour it in lol
Help welcome
	Threads: 141
 35
		milk bottle cut at an angle and duct tape ftw
	Threads: 151
 14
 Car Model/Spec: 306 D-turbo
		Robingsons pop bottle ones with the big neck, screw into the fuel neck cut bottom of bottle off
Punch 3 holes in the tin opposite side of the lid and pour
Empty the drum in less than 30 seconds
Team Doesn't own a 306
		I use a 20litre jerry can...tenner on ebay...
then put two holes in opposite end to the funnel...empties in roughly a minute...
but working on a pump with this:
from the veg oil tank!
	Threads: 343
 15
		23-02-2013, 10:58 AM
(This post was last modified: 23-02-2013, 11:00 AM by Chris_90.)
		 (23-02-2013, 10:37 AM)ozonehostile Wrote:  milk bottle cut at an angle and duct tape ftw
I tried this the first time but the bottle wouldnt hold its self there had to get some one to hold it in place for me, would work good if i could get it to hold its self in place.
  (23-02-2013, 10:46 AM)Danny2009 Wrote:  Robingsons pop bottle ones with the big neck, screw into the fuel neck cut bottom of bottle off
dont have any issues getting it out of the bottle just getting it in the tank, will give the robbisons bottle ago see if it will hold its self in place while i pour it in
 (23-02-2013, 10:54 AM)Piggy1987 Wrote:  I use a 20litre jerry can...tenner on ebay...
![[Image: %24(KGrHqRHJDIE7zJynhfqBPCyNZgeBQ~~60_12.GIF]](http://i.ebayimg.com/t/Fuel-Transfer-Pump-Nozzle-Fuel-Trigger-Gun-Diesel-Oil-Petrol-WVO-/00/s/NDAwWDQwMA==/%24(KGrHqRHJDIE7zJynhfqBPCyNZgeBQ~~60_12.GIF)
Its more messing around tho pouring the veg out of its container and in to the jerry can serpose it will work but just messing around
	Threads: 115
		You need to cut the end of the funnel off bud. Trust me   For some reason the end is really narrow, I cut the end off and it flows quicker than I can pour the veg in now!
	Threads: 343
 15
		 (23-02-2013, 11:01 AM)306Puggy Wrote:  You need to cut the end of the funnel off bud. Trust me  For some reason the end is really narrow, I cut the end off and it flows quicker than I can pour the veg in now!
i got one of them black ones were its flexi on the end its quite a big bore on it and i chopped the point bit of the end so it flows better but was still slow, quickest way was the milk bottle way just finding a way to get it to hold its self in place while im pouring it in
		Get a funnel, go to scrappy and pull off string bit from parcel shelf, attach string bit to boot lid when open, attach other end to funnel, pour away
	Threads: 151
 14
		works wonders mate screws in and holds well dosent move while pouring veg in give it a go
	Threads: 343
 15
		 (23-02-2013, 11:31 AM)Ruan Wrote:  Get a funnel, go to scrappy and pull off string bit from parcel shelf, attach string bit to boot lid when open, attach other end to funnel, pour away
Sounds daft but might work lol will be one of my options if i carnt get the other ideas to work,
  (23-02-2013, 11:34 AM)Danny2009 Wrote:  works wonders mate screws in and holds well dosent move while pouring veg in give it a go
will do mate need to get some more veg to try it lol
	Threads: 56
 19
 Car Model/Spec: Moonstone HDi
		Gee jays in alfreton have got syphon hand pumps in for a quid mate.
I use it when I bulk buy diesel
	Threads: 34
 8
	Given 8 thank(s) in 8 post(s)
		Just mtfu! Lol I just rest the funnel (half a bottle) in the hole, n hold the veg with 2 hands and rest it on there, holds it fine
	Threads: 541
 124
		Get a funnel (the big orange ones are best) stick it in the tank then get your veg drum, cut an air hole in the back of the handle. Stand close to the car and rest the funnel on your stomach so it dosent fall over, lift the barrel, tuck it under your arm and start pouring, use the neck of the barrel to steady the funnel
	Threads: 465
 114
 Car Model/Spec: Vauxhall
		expensive but i can recommend a Polarn Pump for a jerry can it will empty a whole can in around 40 seconds
we use them on rallys for transfering fuel
	Threads: 0
 45
		Bottom rad hose wedges into the fuel filler lovely, duct tape a normal funnel to it.. Ask Dan!.. I never spilt a drop.
Still got it somewhere if you cover post!
	Threads: 343
 15
		 (24-02-2013, 09:13 PM)JJ0063 Wrote:  Bottom rad hose wedges into the fuel filler lovely, duct tape a normal funnel to it.. Ask Dan!.. I never spilt a drop.
Thanks mate will keep this in mind gona try the other options first gona get some veg today so will see how i get on
	Threads: 63
 26
 Car Model/Spec: GTi6
	Threads: 343
 15
If only i had a roof rack lol
	Threads: 63
 26
		Put the string over the roof and trap it in the window or door the other side or something
	Threads: 183
 20
		 (23-02-2013, 12:18 PM)Oil-burner Wrote:  Gee jays in alfreton have got syphon hand pumps in for a quid mate.
Bulk diesel... Please tell me more
	Threads: 124
 26
 Car Model/Spec: Megane DCiR
		I hold funnel with one arm n barrell with other n pour but not ran veg for year or so now
	Threads: 343
 15
		 (25-02-2013, 09:44 AM)CJ_Derv Wrote:  I hold funnel with one arm n barrell with other n pour but not ran veg for year or so now
Problem is im not strong enough lol
	Threads: 124
 26
		Some good replies on here tbh
Try some rubber hose about 12" tapped to a funnel n drop the rubber tube into tank should hold it in place then bud
	Threads: 343
 15
		 (25-02-2013, 12:59 PM)CJ_Derv Wrote:  Some good replies on here tbh
Got some veg today so probably be filling up tomorrow, got a milk bottle with a funnel end on hopefuly that will work if not got a siphon pump on its way if not plenty of other options sure i will get there in the end.
Thanks for all the replys guys
	Threads: 14
 7
	Given 5 thank(s) in 5 post(s)
		Decant half the 20L into an one of the 20L containers you've previously used.
It's easy to hold a funnel and pour in 10L, then just switch containers and pour in the other half.
also with the funnel there might be a gauze filter in the bottom, just oik it out with a screwdriver and the veg will flow much better.
	Threads: 42
 Car Model/Spec: 306 XRDT
		I just take the seat up and undo the tank cap and pour it in
	Threads: 183
 20
		 (25-02-2013, 02:46 PM)D@wson Wrote:  I just take the seat up and undo the tank cap and pour it in
/thread sounds easiest and smartest.
	Threads: 36
 Car Model/Spec: 1996 306 xt auto
Best idea so far
when in doubt...... flat out.
 21
		get a old water pump from a caravan. cheap as chips. look on fleabay
	Threads: 14
 7
		 (25-02-2013, 07:31 PM)bingham123456 Wrote:   (25-02-2013, 02:46 PM)D@wson Wrote:  I just take the seat up and undo the tank cap and pour it in
Best idea so far
Except the old tank seal is renowned for being a pig to get to seal properly, so constant moving of the tank access is only going to make it worse.
