04-02-2013, 10:12 PM
		Bought a 15 inch Sony sub the other day 1400 watts peak anyone know what's the smallest amp I can use and still keep sound quality
					Ice help
		04-02-2013, 10:14 PM
		What exact sub is it 1400watt is its peak so you don't want to be running it around there constantly do you have any more info on the sub
		04-02-2013, 10:17 PM
		04-02-2013, 10:31 PM
		Ahh 1 one of those I had 2 of these in 12 inch few years back
Specs are XS-L156P5: Size (inch) 15 Dual Voice Coil NO General Specifications: Peak Power, IEC 268-5 (W) 1500 Rated Power, IEC 268-5 (W) 450 Impedance (ohm) 4 So I would say running just 1 a mono block amp at a rating of either 4-600 watt should see you getting some decent lows from it your rms rating will be around about 450 rms so a 600 watt mono is sort of your top end Correct me if I'm wrong
		07-02-2013, 10:53 AM
		I would not run more then 300Wrms into that i would use a monoblock such as a AlpineMRP-M350 or Vibe Slick Bass 1 or see if you can find an old school amp that would give that figure bridged?
