306 GTI pads
Does anyone know which pads are the correct ones as the brembo website lists 2 for LUCAS GTI 6 calipers:
I have found both of the ones listed on brembo catalogue on ebay but unsure as they are different size pads?
1)
http://www.ebay.co.uk/itm/300662039149?s...1436.l2649
OR
2)
http://www.ebay.co.uk/itm/270911280772?s...1436.l2649
They both say that they are for S16 which have different callipers to Gti6
ok what size pads are used on the GTI 6 calipers?
These are what I've got for my GTI
http://www.ebay.co.uk/itm/110875257384?s...1439.l2649
MDB 1732 is what you need and only this was fitted to the GTi from start to finish, The parts list S16 comes from Europe as the GTi6 is the S16 BV6 over there
(26-01-2013, 09:42 PM)miles Wrote: MDB 1732 is what you need and only this was fitted to the GTi from start to finish, The parts list S16 comes from Europe as the GTi6 is the S16 BV6 over there
Am I right in thinking there was only ever I set of callipers fitted to gti 6s?
Any body used the brembo pads?
Yes one type only in the UK, no idea about Europe, if using new Disc's thou the Clio pads can be used as they are a tiny bit bigger too, Same calliper as are the rear's
No idea on std pad's I'm afraid
