Threads: 183
20
As far I can I tell the pipes run different.
Threads: 26
Car Model/Spec: ZX Volcane
Pipes are different. Need to swap the rad.
Threads: 136
I am wanting to do this. I brought the radiator and a new bottom pipe but then realised I needed another so I had to put the phase 2 one back on.
The phase one only has one pipe that goes around to the water distributor on the back of the block. I have a silicon end cap to block that. So you'll need one of them or the phase one distributor.
The other thing you'l need is the phase 1 pipe which has the bleed point in it, because the point it attaches to the radiator is lower down so the pipes longer.
Threads: 119
Car Model/Spec: MG ZS180
Hmm, sounds like too much effort really, if it was straight swap with maybe just 1 pipe different then it would be worth it.
Threads: 136
It's only the one pipe you need to get, and the cap. How much do you want the extra room?
Threads: 119
Not that much, would have just been nice to use it for air filter routing. I am going to use a different route for the filter now anyway.
Threads: 136
If Ricky doesn't want any of it then ill be interested in a couple of little bits. I'm in no rush though so if Ricky wants them no worries.
