	Threads: 183
20
	Given 8 thank(s) in 8 post(s)
		As far I can I tell the pipes run different.
![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 26
Car Model/Spec: ZX Volcane
		Pipes are different.  Need to swap the rad.
	Threads: 136
		I am wanting to do this. I brought the radiator and a new bottom pipe but then realised I needed another so I had to put the phase 2 one back on.
The phase one only has one pipe that goes around to the water distributor on the back of the block. I have a silicon end cap to block that. So you'll need one of them or the phase one distributor.
The other thing you'l need is the phase 1 pipe which has the bleed point in it, because the point it attaches to the radiator is lower down so the pipes longer.
	Threads: 119
Car Model/Spec: MG ZS180
		Hmm, sounds like too much effort really, if it was straight swap with maybe just 1 pipe different then it would be worth it.
	Threads: 136
		It's only the one pipe you need to get, and the cap. How much do you want the extra room?
	Threads: 119
		Not that much, would have just been nice to use it for air filter routing. I am going to use a different route for the filter now anyway.
	Threads: 136
		If Ricky doesn't want any of it then ill be interested in a couple of little bits. I'm in no rush though so if Ricky wants them no worries.
