19-12-2012, 09:40 PM
Is there any issue with having boost on idle as long as it dosent start pushing the LDA pin?
Boost on idle
19-12-2012, 09:45 PM
Wouldnt of thought so.. Surely your turbo can be set in such a way it wont be boosting on idle anyway?
19-12-2012, 09:49 PM
Whistle on idle is win
I would have thought the boost generated be quite negligible at idle (if you're on about a vnt). A supercharger on the other hand would probably register a few psi. Don't think it would cause you any problems. Adjust preload /fit stronger spring and it should be fine.
Also, whistle on idle does not = boost!! ![]() Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!)
19-12-2012, 09:56 PM
Wouldn't matter if it dropped the lda pin anyway as the lda lever doesn't do anything until the throttle arm is moved.
19-12-2012, 10:06 PM
I know, mine doesn't boost on idle but it whistles, i just presumed the whistle would be louder
19-12-2012, 10:59 PM
other than raping the turbo for no reason, no harm...but if its boosting on idle, sounds like if its a vnt you have the vanes stop wayy to far out...unless we are talking superchargers here
| #DervMafia | ![]() |
