bit of advice?
File Line Function
/global.php 961 eval
Warning [2] Undefined array key "thxdsp_outline" - Line: 1 - File: inc/plugins/thx.php(309) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php(309) : eval()'d code 1 errorHandler->error_callback
/inc/plugins/thx.php 309 eval
Warning [2] Undefined array key "thanks" - Line: 40 - File: inc/functions_post.php(966) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/functions_post.php(966) : eval()'d code 40 errorHandler->error_callback
/inc/functions_post.php 966 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 48 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 48 errorHandler->error_callback
/showthread.php 1651 eval
bit of advice?
Quick few questions for fellow oil burners
Finally got my stage one tune done after some much needed advice from you guys.
I've seen on a few websites that ppl have de filtered their cars, is this safe to do?
and what's the benefit to unplugging the egr valve
Thanks in advance
Unplugging the EGR valve isnt really worth doing unless you are going to take off the inlet manifold and clean it out properly too.
De-filtering a car isnt great to be honest. It most likely wont do any damage over the short term (~5k) but over long periods it will wear the engine out more and fill the compressor housing with shit. The only reasons most people do it are for 1. Noise, and 2 because fitting an intake system/filter onto a bigger turbo is a bit of a ballache and most people cant be arsed. Personally keep it filtered, but replace the standard air intake piping and box with a bit of flexi pipe off the turbo and a cone filter.
egr unplug is a good thing. make sure engine is stone cold when you do it or it will be open a bit giving you leak. is green plug behind battery housing just unplug and there you go. but be prepared for loads of smoke until inlet cleans itself lol
De-filtered only good if you want to increase the likely hood of something getting sucked in and destroying your turbo. yes alot of people do it but i wouldn't and that is my opinion. Filter's are used for a very good reason and don't disturb air flow if they clean
Cheers for the advice mate,
Any suggestions on the cone filter to use?
They are all much of a muchness tbh mate. I doubt you would notice any difference between a £10 ebay cone filter, a £40 KnN/Pipercross cone filter or a £170 Closed air induction filter system, they all do the same thing in reality. A good cold air feed to the filter to reduce heatsoak is more important Smile
Me personally have stuck with the stock set up there is a mighty car mods youtube that shows why but others may disagree
Biggest problem with the standard system is the restrictions in the intake piping.
I've seen the mighty mods video mate, to my understanding they basically sais that there were no power gains, in some cases a loss, all it can go is increase flow?
none what so ever and brings me to my next one
Me personally never noticed much of a difference from Pat i changed to a cone and did a extra cold air intake so with Project T i've stayed stock and Project T goes way better
But everyone experience is different so what i felt never worked may work well for others
Bear in mind they didnt test it on a turbo charged diesel Smile Granted it wont get you any gains but i bet it wont make it worse.
The thing is i'm off the thinking peugeot put a lot of R&D into the intake system so it's designed that way for a reason.
Yes it has restrictions but if a cone would be better on the end of it wouldn't they have done that in the first place?
