Door adjustment
Can I adjust my drivers door sits high at the back near the rear door and as just found out at the car wash leaks like a sieve
Loosen of the bolts on the hinge and rearrge with a jack underneath Smile
Cool wasn't sure if there was a different was on one of these thanks
Just make sure you support it, they can be a bitch to line up so make sure you do it in small amounts loosen a little so you can control the movement rather than the whole lot dropping
a jack you say?
hmm never needed a jack adjusting mine, just loosen enough to allow a little movement, not enough that it flaps about though, then you can easily adjust a small amount without it moving back/wrong way
[Image: signiture.jpg]
I use a jack just incase, I know what I'm like, I would lossen it too much, loose the original line up and never get it right haha
haha do always be careful on first close of the door after adjustment, I nearly forgot and slammed my door, it wasn't very lined up!! would have dented the shit out of the roof
This is the gap I'm on about
[Image: 91CB18EC-8D5E-42F7-AE4A-0735F56D21F2-107...A7BF88.jpg]
