damn gearbox :(
Anyone got any special tips on how to remove that little pin that holds the fork assembly on? I have tried both sets of mole grips to no avail, it's in there solid!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Tried wd40 and knocking the pin inside to loosen it up and try and pull it out ?
Team Doesn't own a 306
Yeah, knocked it in slightly, but still wont come back out. May cut it off and buy a new arm..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Get a good set of mole grips and twist and pull, if that dose not work try some heat on it
Mine was solid and wouldn't move, so we got the Oxy out on it.. I used mole grips and twisted on other boxes though
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Will try heat on it when I next get a chance.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
you sure youre using a decent set of vice grips?
MTFU! clamp as tight as you possibly can on the pin then tip out with hammer, always works for me.
I did it proper tight, in the end it ripped the threads off the adjuster bolt! I replaced that bolt with a gearbox bolt (fitted perfectly) and got it even tighter and it just destroyed the teeth on the grips! Cheap rubbish.. I did have some good ones but they went missing a while back Sad
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Apply small amounts of heat sensibly, then rapidly cool with plus gas in the target area.
Some of them don't want to come out full stop.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Use the claw end of a hammer as if your removing a nail...works every time
I cut the arm so could bang the pin tho. Altho I did have a spare arm lol
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
