Which oil pump should I use?
About to fit an oil pump, got a choice of two. One makes significantly louder clicks when the sprockets turned. Does this suggest one is better than the other?
[Image: 20120704_212316.jpg]
Obviously no one likes you.
On the 306 waiting list.
Take them about and see which one has worn the casing more / has more lash....specs are in haynes if you wanna be anal...clicking means nothing, as one could be dry and one wet with oil...
[Image: sigi-2.png]
Will do, cheers
