04-11-2012, 06:15 PM
		wat does the little orange skidding carlight mean it only come on when i changedbto the spare? ?????
					dashboard lights
		04-11-2012, 06:20 PM
		abs/ebd problem.
Team Eaton 1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft
		04-11-2012, 06:21 PM
		Is the spare a lot smaller than the others?  If so the ABS sensor will be reading faster than the other 3, and thinking theres a fault....
		04-11-2012, 06:24 PM
		Could be y then im on 205 40 17 i think the spare is a high 14 but its smaler
		04-11-2012, 06:26 PM
		So youve got 17s on 3 corners and a 14 on the other? in which case, thats your reason...one wheel is spinning faster than the others
		04-11-2012, 07:36 PM
	 (04-11-2012, 06:26 PM)Niall Wrote: So youve got 17s on 3 corners and a 14 on the other? in which case, thats your reason...one wheel is spinning faster than the others Not necessarily, if the rolling circumference of both the 17's and 14 is the same then there will be no difference. Having said that there is likely to be a small difference but I'd doubt it'd be enough to upset the ABS? More likely to have knocked the sensor when swapping the tyre? ![[Image: 306Green5DrSig.png]](http://i1011.photobucket.com/albums/af232/burnmw/Pug/306Green5DrSig.png)
		04-11-2012, 07:48 PM
		As Martin says....but I guess the 14 is a 185/55 anyway.  As people can't seem to keep to the standard 65 profile!
		04-11-2012, 08:04 PM
	 (04-11-2012, 07:36 PM)burnmw Wrote:(04-11-2012, 06:26 PM)Niall Wrote: So youve got 17s on 3 corners and a 14 on the other? in which case, thats your reason...one wheel is spinning faster than the others i think you would be shocked as to how sensitive they are! But yes i see what your saying. Even still, i reckon there will be a difference. The sensors on them are actually really robust...almost a bit too robust if you ever have to replace one. Unless hes trapped a cable, i reckon its difference in wheel size
Team Eaton 1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft |
