running without a/c
Right, I've got a horrible noise coming from around pullies or that kind of area.
I've been told it was my water pump so I had that changed along with the cam belt but the noise is still their. Then I was told it was the idler pullie so changed that but the noise is still their so now it only leaves the a/c pump. Now, do I risk getting a new one or is it a case of putting a smaller belt in to by pass the pump.
take the belt off, run the car. it'll at least tell you if it's aux belt or cambelt
(27-10-2012, 08:47 AM)Jonny81191 Wrote: take the belt off, run the car. it'll at least tell you if it's aux belt or cambelt
Had all belts changed
I have a working air con pump if you need one.
But the sake of 5 minutes whip the belt off to see if the noise goes
Team Doesn't own a 306
Will crack on with that when I get time. Cheers.
right, im needing a air con pump so anyone got one for me? price posted please and obviously good working condition.
Ask dan if mines still at his, cover postage & you can have it
Roger that, will check tomorrow evening. Pretty sure it's still under the bench :-)
I still have a 55k one Wink
kinda likeing the 55k one. cheers anyway dan/jj006667744. price matey please. need it asap.
You have pm Smile
