Help guys will these fit?
right know nothing about wheels and fitments lol.
http://www.ebay.co.uk/itm/120997231344?s...1423.l2649
without causing any problems? and what kinda tyres will i be needing? spacers?
cheers
[Image: 20gh7o0.jpg]
Yes but unsure on the offset, so they might need spacing, depending on whether your lowered and what size tyres you wish to use.
should bolt on with no issues! make sure you use the bolts ment for those wheels!
was thinking 195 tyres for a bit of stretch but unsure. i would be lowering it on these yes, dont know what you mean though about using the right bolts Huh
There are different bolts for steel wheels compared to alloy wheels Smile
ahhh right, will they cost much?
NOTE!
At the bottom of the ad it says, they are 6.5J so 195 tyres would be the correct fitment for these, (no stretch) any smaller would cock up the handling.
As for the off set they are ET27 so would require a 10mm spacer, this would be needed with these steels to clear the brakes. Also 10mm spacers you would need a hubcentrical spacer i.e the spacers with a spigot ring on.
You will need a tapered steel wheel bolt like the ones below oppsed to the flat seated ones
http://www.ebay.co.uk/itm/PEUGEOT-Peugeo...53ef191622
Hope this helps,
Jamie
im guessing they'd look crap anyway, thought they were 7.5j
