veg??
hi ive got a dturbo with a Bosch and i was wondering what the best mix to start of with for example 50/50 of diesel and veg, also are there any problems that will follow from using veg oil
cheeers
Only problem is when it gets cold but just thin it down with petrol or similar
No set percentage just dive in at whatever you want
Keep a spare fuel filter in the boot in case and I'd change it 2x as often at least
Just sling it in.
On the 306 waiting list.
any amount is saving money, even a gallon a tank.
doesn't really seem to matter though, until it gets cold!
2 stroke is meant to help thin it out a bit when things get lumpy
[Image: mcetg0.png]
If you can find some sunflower oil at a good price put that in instead over the winter as it needs to get a lot colder than veg before it starts going lumpy.
As already said change the fuel filter after 100 mioes as the veg is quite corosive and will clear all the shit out of the tank/lines and clog the filter very quickly. Then change it at half the usual recommended intervals.
As for the mix, I just run it straight in the summer and a 50/50 mix in the winter.
HDi Cabby Project Click
