injectors
Might sound stupid but are the injectors the same that you use for a lusac and a bosch or are they the same? If different can you use any or doesn't that matter?
Lucas injectors are different to bosch ones.... With a lucas pump you use lucas injectors.. same with the bosch. if thats what you ment
A bosch pump will run fine with lucas injectors tho
Well I didn't know if the bosch were bigger and if so if you could just connect them to the lucas lines?
No because i think the firing order is different so you have to use the right lines.. but the injectors can be swapped and changed.. but you should use the right injectors really, for proper running.
They have different break pressures iirc
lucas are 155bar and bosch are 175bar AFAIK
[Image: sig-1.jpg]
SOLD
The bosch injectors as stated are 175bar, Lucas are 155bar break pressure....
The Bosch injectors will run much better in a Bosch pumped car, don't go swapping between the two - you can run a Bosch on Lucas injectors, it just makes for a shitty running engine since the higher break pressure retards the timing and there's worse atomization. I wouldn't go putting Bosch 175s on a Lucas pump, you're likely to just f*ck the pump... They're pretty weak from the factory.
