Threads: 42
Car Model/Spec: 1.9 XUD
07-08-2012, 05:48 PM
Heard a hissing earlier, had a look and there's orange from the rad cap
Tightened the head bolts a bit, but it's still pressurising.
I know it could be the Head gasket, or warped head but is there anything else I should look for?
Going to do a compression test before I lift the head, just to check, but I guess that's pretty trivial
Also, I assume it'll be OK to drive as long as I loosen the rad cap every time I park, to stop water going in the cylinders.
Threads: 150
14
Car Model/Spec: 306 HDI
is the water bubbling over excessively? take the cap off and run it for a bit
306 HDI, soon to be XUD
Threads: 42
It is yes.
Just driving it home then, after 2/3 minutes, the low water fuel light kept flashing on and off, but there wasn't silly amounts of water that had escaped. So filled it up and after about 40mins of driving, it was still near enough full, the level went down a little.
I didn't exceed 40mph and engine temp didn't rise above 70, is there some kind of point where it gets to and then just drains for the fun of it??
Massive explosion of water though when i released the cap!
Threads: 202
58
(07-08-2012, 06:52 PM)c.gerrard Wrote: the low water fuel light
I'm not helping am I...
Threads: 42
 WOOOPS
Deffo low water, I would be very worried if the low fuel light was on!!
Threads: 59
Car Model/Spec: 306 D-turbo
Could be just an airlock try bleeding it to see what happens.
Threads: 41
Car Model/Spec: Dtractor
Surprising how reliable these things are even with a blown head gasket!, get it done, but should be alight to pootle about in for a while. Ruan has silly blown head gasket and still rags it everywhere lol!
Long as you don't let the head fill with air, you're fine...
Keep your heaters on hot pointing at your hands, when they go cold - STOP. That's because the head now has no cooling and has filled with air and you need to pull over and re-bleed the system.
Threads: 42
Ok, cheers for all the advice.
Just want to rule eveything out before having to lift the head. It's a new head and gasket that's been on for no longer than a month!
Threads: 150
14
Have you had a decent look at your rad? i would lose shit tonnes of water with my old rad :L
worth pressurising the system
Threads: 124
26
Car Model/Spec: Megane DCiR
(09-08-2012, 10:39 PM)c.gerrard Wrote: Ok, cheers for all the advice.
How long after having 'New Head and gasket' did this problem arise? who did the work? was the head pressure tested?
when you take cap off and rev it does it bubble a lot?
does your heating get very hot, as if your heater matrix is blocked ive had mine get these symptoms again and had to have another gasket as Ruan has mentioned in the 'do not bypass heater matrix thread' it created hotspots in the head
CJ
Threads: 42
14-08-2012, 10:40 PM
(This post was last modified: 14-08-2012, 10:43 PM by c.gerrard.)
It's happened about just over three weeks after it's been fitted. Jonny (on the forum) and myself did it all, all done to the letter of the law, so to speak haha, so don't see how that should be an issue! No, never got the head pressure tested.
Yes, there are a lot of bubbles.
Heating isn't out of the norm, not fiddled with anything heater matrix related.
The rad is amazing condition, stumbled across a mint Nissens one in the scrapyard.
Tried pressurising the system as well, but that hasn't worked. It's amazing how much rust and crap there inside the system!!!
Car Model/Spec: 306 D Turbo
Have you checked the rad cap. I thought mine had gone again but turns out the cap wasnt sealing properly allowing water to come up out of the drain pipe.
Worth a look anyway.
Threads: 124
26
What were symptoms last time head gasket went? Should have got head pressure tested if you done it by the law lol as these heads can be a nightmare if theyve got to hot
can vouch for londondan86 though ive thought hg once and turned out to be cap shitty metal one caused problems replaced for oem plastic one and give a good flush with dishwasher tablets and bled up using a ribena bottle fits in res and lifts hight of the water level to get all air out once stat opens
Threads: 42
Yeah, tried three different caps on!
(15-08-2012, 01:52 PM)CJ_Derv Wrote: can vouch for londondan86 though ive thought hg once and turned out to be cap shitty metal one caused problems replaced for oem plastic one and give a good flush with dishwasher tablets and bled up using a ribena bottle fits in res and lifts hight of the water level to get all air out once stat opens
Don't think you'll find that method in the Haynes guide haha.
Last time the HG was blown between the water jacket and a cylinder.
Yeah should have done, but MEH, more moneys I guess.
