	Threads: 178
28 Location: Odiham/Basingstoke/W-s-M
 Car Model/Spec: HDi!
 Thanks: 0Given 1 thank(s) in 1 post(s)
		10-08-2012, 09:47 AM
(This post was last modified: 10-08-2012, 09:48 AM by Just Sean.)
		Just a check to see if i have everythnig and i dont need anything else!
So far ive got  Universal 2.25 intercooler kit from ebay
C5 hdi 110 bottom pipe
An assortment of 2.5 and 2.25 pipes, some rubber 90 degree reducers too and about about 4 2.5 inch straight rubber joins
the pipe needed to come down off the turbo
a 'box' of 406hdi rubber bends and straights
Im sure ive got enough pipework, but is their anything else that im liable to need?
	Threads: 343
15 Location: Chesterfield
 Thanks: 4Given 3 thank(s) in 3 post(s)
		Have you got the inlet elbow off the 406 110bhp?? other than that looks like you got every thing when you do it take pics step by step wana see how you get on as im doing mine soon when i have collected enough pipes
	Threads: 178
		No, i thought you could use either the c5 pipe or the 406 one! :/
	Threads: 82
27 Location: North Somerset
 Thanks: 6Given 22 thank(s) in 22 post(s)
		Sean he's on about the ally inlet elbow from the 406, also you'll need a 41mm (IIRC) long legged 90 degree silicon to go from the lower C5 pipe to the turbo mine cost about £7 from an eBay shop. Also a 406 110 HDi top rubber pipe is fairly useful too
	Threads: 178
		10-08-2012, 10:22 AM
(This post was last modified: 10-08-2012, 10:25 AM by Just Sean.)
		 (10-08-2012, 10:15 AM)Midnightclub Wrote:  Sean he's on about the ally inlet elbow from the 406, also you'll need a 41mm (IIRC) long legged 90 degree silicon to go from the lower C5 pipe to the turbo mine cost about £7 from an eBay shop. Also a 406 110 HDi top rubber pipe is fairly useful tooThis? With the 406 top pipe, could i not just replace that with the pipework that ive got?
And im not sure on the inlet elbow. Ill have to ask the guy i bought the box of bits from!
PS; This  is the c5 pipe i bought
How does the FMIC Attach to the car btw?
	Threads: 82
		You could... but the bay looks a lot more OEM and is a straight fit to the 406 inlet, you'll need to make some brackets yourself for the cooler to bolt too then obviously bolt them to the car. You NEED that 406 elbow too, can't do your FMIC without it so make sure you get one before you start
Yeah that eBay link is the same one that i bought: http://www.ebay.co.uk/itm/41mm-90-Degree...1117wt_876
	Threads: 178
		 (10-08-2012, 10:26 AM)Midnightclub Wrote:  You could... but the bay looks a lot more OEM and is a straight fit to the 406 inlet, you'll need to make some brackets yourself for the cooler to bolt too then obviously bolt them to the car. You NEED that 406 elbow too, can't do your FMIC without it so make sure you get one before you start
Can i just use L brackets and bolt it in? Is their holes to bolt it in or will i need to drill them?
Will try and find one on fleabay
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		10-08-2012, 10:33 AM
(This post was last modified: 10-08-2012, 10:34 AM by Poodle.)
		 (10-08-2012, 10:22 AM)sean-306 Wrote:  PS; This is the c5 pipe i bought
That's not what people mean by "C5 lower pipe" mate, you're looking for a solid plastic one, goes under the sump/g'box. You'll need to attach the FMIC to the car with brackets. I explained this in your other thread, you might have a bit more luck if take notice of the advice you've asked for.
And as midnightclub says; you need the 406 inlet elbow, bodging something on would be messy and might not work properly.
	Threads: 178
		 (10-08-2012, 10:33 AM)Poodle Wrote:   (10-08-2012, 10:22 AM)sean-306 Wrote:  PS; This is the c5 pipe i bought
My sincerest apologies poodle, i have just reread your post, originally i just thought you had quoted my post and told me to 'search'
Muchos Kudos for your help.
	Threads: 82
		Yeah that pic of that 'c5' pipe you bought is completely the wrong one, like poodle says it's a plastic pipe which runs below the gearbox
	Threads: 178
		cock!
	Threads: 82
		Alternatively you could buy the 406 110 HDi lower pipe and it'll fit straight on without the need for another silicon
	Threads: 178
		10-08-2012, 10:51 AM
(This post was last modified: 10-08-2012, 10:52 AM by Just Sean.)
		 (10-08-2012, 10:47 AM)Midnightclub Wrote:  Alternatively you could buy the 406 110 HDi lower pipe and it'll fit straight on without the need for another silicon
So if i get that pipe, that will attach to the turbo and i wont need the 41mm pipe?
And i wont need the citroen c5pipe either?
This  any good?
	Threads: 82
		correctomundo, it doesn't flow quite as well but tbh.. i don't think you'd notice the difference
		10-08-2012, 10:54 AM
(This post was last modified: 10-08-2012, 10:54 AM by Poodle.)
		No problem fella, I know i come across as a bit of a pompous twat sometimes, but i do mean to help really lol. Tbh i did kind of jump to the conclusion you were the kind of noob that asked the same question three times, which is obviously unfair, so my own apologies for that. Kiss and make up?
EDIT: That's the wrong one again matey, give me a sec.
	Threads: 178
		 (10-08-2012, 10:52 AM)Midnightclub Wrote:  correctomundo, it doesn't flow quite as well but tbh.. i don't think you'd notice the difference
Ok good! I can almost see the light at the end of the tunnel!
and the top pipe?
And are any of these any good?
http://www.ebay.co.uk/sch/i.html?_odkw=4...r&_sacat=0
	Threads: 82
		nope, scrappy might be better mate
	Threads: 178
		 (10-08-2012, 10:54 AM)Poodle Wrote:  No problem fella, I know i come across as a bit of a pompous twat sometimes, but i do mean to help really lol. Tbh i did kind of jump to the conclusion you were the kind of noob that asked the same question three times, which is obviously unfair, so my own apologies for that. Kiss and make up?
I did think that! Fwends? x
	Threads: 82
		There's a part number for it somewhere but i cannot remember where!
		10-08-2012, 11:08 AM
(This post was last modified: 10-08-2012, 11:09 AM by Poodle.)
		Right, seems there aren't many about on ebay atm, but found these listings:
- Full set here: http://www.ebay.co.uk/itm/CITROEN-C5-200...231c6458c8 .
- Alternatively here's the "406" style bottom pipe: http://www.ebay.co.uk/itm/Peugeot-607-2-...3f06b0c27d  (the small pipe cable-tied to it isn't necessary).
- Heres the "C5" style pipe: http://www.ebay.co.uk/itm/CITROEN-PEUGEO...1c29d72266 .
- And here's the inlet elbow: http://www.ebay.co.uk/itm/Peugeot-306-hd...1e70e774b7
None of those are at great prices, but at least you know what you're looking for now.
Also, not the right one, but looks interesting: http://www.ebay.co.uk/itm/PEUGEOT-407-60...3a784e5ef5  Anyone else know if this might fit...?
  (10-08-2012, 11:00 AM)sean-306 Wrote:  I did think that! Fwends? x
Hahah deal, car fwends!
	Threads: 82
		Doesn't look like it will mate the bend is nowhere near sharp enough to curve below the gearbox from the turbo
	Threads: 178
		Thanks poodle! Found this, http://www.ebay.co.uk/itm/PEUGEOT-407-20...5d344a8b94 ... Im right to presume this will endmyquest for parts wont it!?
	Threads: 82
		I don't think so sean, the lower pipe is from a 2.2 16v HDi IIRC
	Threads: 178
	Threads: 82
		God aint gon' help you now bro! lol
	Threads: 178
		Its fudjing annoying! Hate being on this op now!! Need to spend an afternoon in a scrap yard with a 407
	Threads: 266
18 Location: Somerset
 Car Model/Spec: 205 DTurbo
 Thanks: 73Given 7 thank(s) in 7 post(s)
		Scrap yards are always the best option if you have tools and access to one as Danny will tell you.
	Threads: 82
		haha yeah! indeed they are, shame there isn't many 'newer' cars in our scrappies though :/
	Threads: 178
		^^ Explain!
 If anyones going to a scrap yardkeep your mince pies peeled for me!
	Threads: 343
		These are the pipes i bought off the 406 you will be better with this one instead of the one with butterfly valve in as you will have to make something up to remove the butterfly valve, this on i got dosnt have that in and the pipe just fits straight on also the 406 bottom hard plastic pipe from off the turbo will bring it to in front of the sump  ![[Image: 306new29.jpg]](http://i552.photobucket.com/albums/jj332/mazda_323f/306new29.jpg)
