Torsion bar loweing.... Best way to remove off set washer??
As above really how can i remove the off set washer i had the same problem on my 106 the off set washer was stuck in and now its the same with my 306 i tried all sorts with my old 106 heat, wd40, hammer, a bigger hammer, shouting and swareing but it still didnt move...... just had a go with the 306 and its the same rusted in how can i get it out?????
Wire brush drill bit to clean it out
DW40 lots of it
dig the crap out wiv a small flat head so it has some where to go.
A blower on the air line to blow the crap out. (as much pressure as you can get in the compresor helps)
Some hard blows with a center punch/chisel.
Should do the trick
As above, works every time
Did you watch my video? Think i showed using a chisel / screwdriver to knock them down...
[Image: sigi-2.png]
(08-08-2012, 12:10 PM)darrenjlobb Wrote: Did you watch my video? Think i showed using a chisel / screwdriver to knock them down...
Screw drivers are pants for doin that. You get to much bounce Tongue
Not seen your vid no, but theres not much room to get any thing in there.... will have another go some other day will just keep covering it in wd40 see if it losen's it off
You must have pants screwdrivers then Wink
Any screwdriver with steel right thro into hammer end is fine...
[Image: sigi-2.png]
Weres this video to
Snap on FTW. They are rubber handle ones though so you loose alot of the shock through that. So yeah your right tgey are shit for beating on. Lol
(09-08-2012, 04:36 PM)simonx3 Wrote: Weres this video to
Youtube. Search- darrenjlobb torsion bar
