	Threads: 37
		got some fli 4.5" (i think) i want to stick in the door. had a look at the standard ones yesterday and there is that yellow plug into the standard speaker. how do i swap it for my flis? cut the yellow plug off then attach the wires?
on the flis its just a metal bracket shaped like a B - 2 small holes that wire just wraps around.
also the same for speakers on the parcel shelf?
	Threads: 151
14
Car Model/Spec: 306 D-turbo
		You can pull the yellow connector apart iirc and inside there are spade connectors  that will pull out with a bit of a tug, but i usually just cut the plug off and wrap it round the terminal on the speaker works fine
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
Team Doesn't own a 306
21
		1... 4.5" wont fit. iirc its 6.25".
2.... cut blocks off and get some spade connectors.
	Threads: 37
		Might b 6.5 I'll have check lol. Thanks guys
	Threads: 37
		too small =[ anyone recommend some good speakers that are a straight swap?
	Threads: 37
		So sound nice at high levels? Might have to get some
	Threads: 164
25
Car Model/Spec: Gti6
	Given 4 thank(s) in 4 post(s)
		tbh its easy enough to get a sub and amp package and run the cables
