	Threads: 8
0 Thanks: 0Given 0 thank(s) in 0 post(s)
		Does anyone know what turbo I could go with and the easyest way to fit it,or what mods need doing?will the gt15 fit in the position it is in on the 2.1 in a 306 or will it hit bulk head?will a 1.9 dturbo exhaust manny fit a 2.1 td? Just need to know the best way to go about it???? thanks
	Threads: 4
1 Thanks: 0Given 0 thank(s) in 0 post(s)
		Virtuall nothing mixes but you can fit the good old bosch pump! I sat in an 11mm, fmic'd 2.1dt, it was dyno'd 160bhp and was very comparable in power/torque and power delivery to a stage 2 hdi.
12 Location: Wrexham
 Car Model/Spec: 306 D Turbo
		Manifolds defo wont fit due to the extra ports on the 2.1. However the turbo should still fit onto the 2,1 manifold assuming the stud pattern is the same.
	Threads: 8
		 (12-07-2012, 10:56 AM)con67 Wrote:  Virtuall nothing mixes but you can fit the good old bosch pump! I sat in an 11mm, fmic'd 2.1dt, it was dyno'd 160bhp and was very comparable in power/torque and power delivery to a stage 2 hdi.
right did you have to make up ur own exhaust and weld turbo?cause the turbo sits different?It needs to be spun around cause the exhaust won't line up,that is what I am not sure of.
	Threads: 138
72 Location: Milford, Surrey
 Car Model/Spec: Mincebus
		 (12-07-2012, 03:16 PM)Mountie66 Wrote:   (12-07-2012, 10:56 AM)con67 Wrote:  Virtuall nothing mixes but you can fit the good old bosch pump! I sat in an 11mm, fmic'd 2.1dt, it was dyno'd 160bhp and was very comparable in power/torque and power delivery to a stage 2 hdi. right did you have to make up ur own exhaust and weld turbo?cause the turbo sits different?It needs to be spun around cause the exhaust won't line up,that is what I am not sure of.
I don't think he made anything up!
Astor 'X' 4 GTi6-6  - SOLD!
	Threads: 4
		The owner is on the other forum, theres a thread his username is something like 2.1dturbo
	Threads: 8
		 (13-07-2012, 08:39 AM)con67 Wrote:  The owner is on the other forum, theres a thread his username is something like 2.1dturbo
Witch site mate?? cheers
	Threads: 3
 Car Model/Spec: 205 1.8 TD Mardi Gras
		15-07-2012, 10:28 PM
(This post was last modified: 15-07-2012, 10:33 PM by Jarrus.)
		Check my project thread on theywhoshallnotbenamed
im running a 2.1 with 11mm and td04,
Theres is literraly no room behind the engine for a turbo, the 1.9 k14 and T2 bolt patterns line up on the manifold but the mount the wrong way around and foul the inlet...and besides... the standard turbo is pretty much the same as the 1.9 t2 but the inlet side faces the gearbox, you will have to hit the bulkhead to fit the standard turbo, anything will require you to relocate it....
I should also mention if you want big power from your 2.1 then youll need to do something with the cooling system as it runs hot when making loads of power....
 http://www.theywhoshallnotbenamed/forum/...-deserves/
Check that...
	Threads: 8
		 (15-07-2012, 10:28 PM)Jarrus Wrote:  Check my project thread on theywhoshallnotbenamedim running a 2.1 with 11mm and td04,
 Check that...
does the 1.9 gearbox and flywhell fit it??? Also what mods got to be done.I will be running tdo4 but moving it above gearbox...
	Threads: 3
		1.9 gearbox and flywheel does fit, 1.9 ancilleries also fit, make sure you keep everything off your 1.9 just in case, the 406 uses a slightly different aux belt setup than the 306, use the 306 aux belt setup, and use the 306 alternator/pas braket, use the 306 starter motor, and also the water pump is totally different and has a sort of tank fitted to it with a themostat and cover, make sure you get this all complete with your engine, I didnt and i had to make something instead, and you cant buy just the cover from peugeot you.have to buy the lot which is 200 quid,
Also the 406 must get its tacho reading off the alternator as there is no flywheel sensor, so i had to put the 1.9 one in, i made a hole and braket and tapped another hole in the block and it works a treat,
Also use the 406 xud11 ip braket as its a better fit, bosch pump will fit on it...
O yeah, battery will have to go in the boot so sort that out as well,
Hope it helps...
Brett
	Threads: 266
18 Location: Somerset
 Car Model/Spec: 205 DTurbo
 Thanks: 73Given 7 thank(s) in 7 post(s)
		Bit of an old bump but credit to you Jarrus, the build looks really good, just sat and looked through the project and it looks like its been done to a high standard!
	Threads: 3
		 (10-08-2012, 01:06 PM)silverzx Wrote:  Bit of an old bump but credit to you Jarrus, the build looks really good, just sat and looked through the project and it looks like its been done to a high standard!
Cheers dude, sorry for the belated reply
More to come yet, I may move the project over here
