22-06-2012, 09:34 PM
		Hey just looking for some advice im thinking of flushing out my rad and puttin rad flush in is there any advice on putting new coolant back in and wat i should do thanks
					coolant
		22-06-2012, 09:51 PM
		Its the 1.4 meridian how do i bleed it back through
		22-06-2012, 10:41 PM
		Bleed point at the back on coming of the heater matrix. Make sure you cut the top off a small coke bottle and fill it till half way up there. Helps push the air out the bleed nipple as the water level will be higher.
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
		24-06-2012, 09:32 PM
		What coolant type should be used though, red/blue? http://th01.deviantart.net/fs70/PRE/f/20...4ocxyw.png 1 rep to who ever gets reference pic
		03-07-2012, 09:05 AM
		It would depend on what you are using actually.  While there are those who would want to consider them to work without any problem, there are those that are going to have some problems in how they are functioning well. Hopefully that the simple drain, flush, fill and bleed method would work really well for you.
		03-07-2012, 01:55 PM
	 (24-06-2012, 09:32 PM)lolsteve Wrote: What coolant type should be used though, red/blue? Team fortress 2? My brother plays it a lot ![[Image: IMG_20130925_181339_zps95df48fa.jpg]](http://i727.photobucket.com/albums/ww278/4WayDiablo/IMG_20130925_181339_zps95df48fa.jpg)  |
