My 306 is overheating only 62k on the clock been looked after just had major service started overheating quickly been stripped down not the water pump or thermo any ideas
306 1.4 meridian over heating help
04-02-2019, 07:04 PM
What was done in the major service? Has the head been off at all? Is it leaking coolant?
04-02-2019, 07:29 PM
Usually head gasket on those engines.
04-02-2019, 08:02 PM
(This post was last modified: 04-02-2019, 08:04 PM by Jackginn0507.)
(04-02-2019, 07:04 PM)Eeyore Wrote: What was done in the major service? Has the head been off at all? Is it leaking coolant? Fuel filter air filter oil filter spark plugs oil change had rocker cover gasket seal changed due to a small oil leak water pump checked ok new thermostat checked for blockages flushed bleed system not losing any coolant or oil
05-02-2019, 08:39 AM
Check to see if the coolant is pressurising and rad hoses getting hard.
06-02-2019, 10:59 AM
(This post was last modified: 06-02-2019, 11:01 AM by pug306driver.)
and any cold patches on the rad when the engine is up to temp, or is the matrix blocked so no cooling air passes thru it, does the fan cut in a high temp?? to bring high temp down??
be prepared to drive the car if the high temp fan does not cut in so as to cool down the engine else it will overheat and boil, real problem then!!! any mayo in the engine oil and loss of coolant, how as inside rocker cover when it was removed recently?? does the exhaust make a "fizzz" sound when engine revved, suggesting a blocked exhaust ( and poorish performance ) ? does the heater work and push out hot air??
12-02-2019, 08:14 AM
(04-02-2019, 08:02 PM)Jackginn0507 Wrote: How did you bleed it? The coolant system on these can be a right twat to get all the air out of. 2 litre plastic bottle with the bottom chopped off to raise to the coolant level and push the air out works for me. Check your rad cap is OK and on properly too.....had that one during an MOT once.
2001 BMW 330Ci
2012 VW High Up 1988 205 GTi 1.6 1990 205 Mi16
13-02-2019, 06:05 AM
If it's had a new thermostat and was ok before that, I'd suggest the system has an airlock somewhere.... Alan's advice is good.
