14-01-2018, 05:38 PM
(This post was last modified: 14-01-2018, 06:50 PM by cpikey316_.)
I am having a problem with a toilet. Some of the water is always seeping through, so the cistern empties every hours of so causing it to be refilled.
Opened it up, found that pushing large hollow cylinder in the centre solves the slight trickle going into the toilet, so I thought there might be some adjustment on the part, so I removed the whole white part on the picture.
I tried moving the grey part up and down, this seemed to do nothing, however, upon reinstalling the part in the toilet, it will no longer flush.
On pushing the button at the top, the plastic cylinder lifts up about 1cm, then falls back down as soon as the button is released (it should stay up to "flush" the toilet!!)
Can anyone shed some light on this?
