I am wondering if a windscreen speed display device intended for later cars than my 1999 xtdt would work. The car has a digital dash so is it possible the speed, rpm and other data is available on the green connector {assuming obd2) in the same way the display device expects?
TIA Ron
Edit: May have been a silly question if a speedo cable is still used on this model, will try to get under for a look sometime.
Another question. The digital trip/service odometer is stuck at oooo and I cant get the service distance set by the instructions in the glovebox manual, any ideas of what I need to do?
I'm supposed to be able to stop the countdown by letting go of the button early and step through the distances but only get the
=0 display.
TIA Ron
=0 display.
![[Image: mcetg0.png]](http://i57.tinypic.com/mcetg0.png)
