19-04-2017, 10:34 PM
anyone able to help is it possible to fit ph1 headlights into a ph2 and any help on wiring the connectors would be awsome
headlights change ph1 into ph2
20-04-2017, 12:05 AM
not really mate, anything is possible but not seen it done myself
Thanks given by: Kcbhoy111846
20-04-2017, 08:02 AM
yeh you could wire it all up but remember you need the phase 1 bonnet to get the lines right. The wings should be the same.
Phase 2 is a bit harder than phase 3 so you need to work out if youve got twin or single optic headlights and may need to change the stalk if that changes. Thanks given by: Kcbhoy111846
first off you will need bumper grill slam panel bonnet
or your car will look like it has a fat lip https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly. Thanks given by: Kcbhoy111846
20-04-2017, 11:20 AM
(This post was last modified: 20-04-2017, 11:42 AM by Kcbhoy111846.)
sounds a bit more complicated than first thought its the wiring thats confusing me just now
(20-04-2017, 08:02 AM)Eeyore Wrote: yeh you could wire it all up but remember you need the phase 1 bonnet to get the lines right. The wings should be the same. thank you |
